why do we need negative voltage regulator ICs?
Old 20th August 2003, 10:47 PM   #11
jkeny is offline jkeny  Ireland
Banned
I used Pedja's circuit for a + & - regulated supply using LM317 for both and it blew the LM317 on the neg supply and a 470 uF cerafine cap after the regulator. Did I do something wrong? It was connected exactly as per diagram in http://www.geocities.com/react_71/au.../gainclone.htm
but using LM317 for a 12 V supply (low ampage)
Old 21st August 2003, 12:26 AM   #12
EJ is offline EJ
Originally posted by paulb
It won't work if you need both positive and negative supplies, and they are coming from the same transformer secondary winding with the centre tap used for ground. In other words, if ground needs to be common between input and output. Otherwise it will work.
anybody knows why?
Old 21st August 2003, 12:29 AM   #13
AudioFreak is offline AudioFreak  Australia
Warp Engineer
On Holiday
AudioFreak's Avatar
Because if you are using your centre tap as a ground reference, you need to be able to regulate both +ve and -ve relative to the centre tap. +ve regulators can only regulate +ve relative to some other point.
- Dan
Old 21st August 2003, 12:56 AM   #14
EJ is offline EJ
Are you meaning that if we need a 0-12vdc-24vdc power supply and our transformer does not have separate secandary windings, we can only use a +12V setup plus a +24V setup, instead of two cascoded +12v setup?
Old 21st August 2003, 01:06 AM   #15
Pedja is offline Pedja  Serbia
I’d say you did. Generally it should work with any positive regulator.
Pedja
Old 21st August 2003, 12:02 PM   #16
Warp Engineer
On Holiday
AudioFreak's Avatar
No that will work fine.
- Dan
Old 21st August 2003, 05:35 PM   #17
EJ is offline EJ
So what's the difference between a 0-12v-24v setup and a -12v-0-12v setup? I still don't get it.
Old 21st August 2003, 09:28 PM   #18
dutch diy is offline dutch diy  Netherlands
dutch diy's Avatar
Send a message via ICQ to dutch diy
In fact there is no difference between your two examples.
It just depends where you put the Com probe of your voltmeter.
However:
Some transformers (like most toriodal) have two entirely separate windings which for example both can supply 24v. (mine does).
There are thus four wires coming out:
- blue / green from one winding
- red / yellow from another winding.
When you connect blue / yellow (or green / red) and measure the AC voltage across the unconnected wires : 0V. Due to cancellation of the sinus wave. You've connected both windings 'antiphase'
When you connect blue / red (or green / yellow) and measure the AC voltage across the unconnected wires : 48V.
In the latter case this transformer is behaving exaclty like a transformer with a center tap.
When you have separate windings you can rectify both windings, put both DC's through a regulator and after regulation connect one positive output to the other negative output. BUT YOU DO NOT CONNECT THE AC-WINDINGS.
Now draw out the schematic when you only have a centre tap and you use two bridges and two positive regulators .
Note that when you connect one of the regulated positive output's to the other negative a closed circuit does exists (through the transformer and connection at the bridges) which imho does look quite tricky. As the the regulator is trying to impose a voltage difference in this loop (the voltage across the regulator ) you're asking for problems.
Old 22nd August 2003, 06:35 AM   #19
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
It can be two things:
0-12-24 _can_ be designed so you MUST connect the load between 0-12 or 0-24 which means that current can't flow into the 12 volt terminal, just out. I think it's quite confusing to write 0-12-24 if you mean -12 - 0 - (+12). I wouldn't do that but this is an american thing I suppose.
Or two true voltage sources which are connected in parallel.
Conclusion: If you are an american there's probably no differnce but surely if you are an european.,
/Per-Anders (my first name) or P-A as my friends call me
Group buy: SSR03 Super Regulator Power Supply. Sign up HERE 18 pcb's in interest so far.
Old 22nd August 2003, 12:38 PM   #20
Warp Engineer
On Holiday
AudioFreak's Avatar
You can put two 12V regulators in series to get 0/+12V/+24V and you can draw power from all 3 terminals without problems as long as you realise that the upper regulator will carry the current for both outputs and so will need to be higher power than the lower regulator which will just carry the current required for the 12V output. As said earlier though, current will only be able to flow out of +12V and +24V.
- Dan
why do we need negative voltage regulator ICs?Hide this!Advertise here!
Positive regulator to produce negative voltage? stef1777 Parts 45 8th February 2008 07:46 AM
Negative shunt regulator > 200 mA ezkcdude Power Supplies 1 22nd December 2006 05:53 PM
Help with negative discrete regulator youyoung21147 Parts 2 28th July 2006 02:45 PM
negative alw super regulator problem piewie Solid State 9 2nd May 2004 09:28 AM
high voltage (>>37 V) negative regulator? capslock Solid State 14 7th September 2002 11:41 PM
Copyright ©1999-2017 diyAudio
