Does somebody have experience or ideas
I want add Class H Rail Step driver for quasicomplementary NMOS amp 60/110 V DC? but I remember in the past some diy member told me quasicomplementary amp does not working with class H Stepdriver (amp will oscillating in negative rail and burn up) ....but I think this information is not true , because its working in commercial NAD 208 70 V / 120 V Rail NAD 208 is commercial Class H quasicomplementary NMOS amp I think it can work if add Class H Step driver from apex member (900 W PA amp with limiter thread ) ANY ideas to increase efficiency for NMOS amp ? I dont like BJT output stage |
#2 |
Whats wrong with bjt output stages ? I say the opposite, i had a go at mosfet output but dident like the sound, maybe for a subwoofer amp but thats it.
I've also seen somewhere that for high output power, bjt is preferred over mosfets. And i seem to prefer the sound from complementary mjt over quasi mosfet.
The point of life is to build atleast one audio amplifier before you die. |
#3 | |
bjt devices cheaper is mass production by chinese manufacturer this is true but not in sound, really... have seen many commercial poor sounding bjt amps and often fails with secondary breakdown. mosfets are much more rugged and free from secondary breakdown if you want share your bjt design, and im satisfied with bjt sound it can be it changed my views but actually...bjt amp no way,... only for bass but big risk of secondary breakdown with high output power For high current i prefer mosfets |
#4 |
POSSIBILE
#5 |
#6 |
HI NMOS i am not test but I now any bjt transister audio amp is working good condition no problem enjoy khalsaaudiocenter@yahoo.com
#7 | |
I have a proto type Class H doing + 2kW peak i 2 ohms with "only" 4 pair BJT and 2 switch MOSFET also tested in reactive and capacitive loads - not problem. It beated 2 x 1000W Class D RCF it was AB tested against - so I think it's a matter of implementation Regards, Robert GS
GroundSound.com Active Sound - Active Listening Digital Crossovers, Power Amplifiers and DIY modules |
#8 |
HI GroundSound I now its tru
#9 |
hi khalsa
greetings nice schematic can you tell schematic is of which company and values of 2sa transistors and the 2sc ones thanking you andrew lebon |
#10 |
transister use 2sc5200 TOSHIBA
| Help needed! strange sound from nmos quasi amp | sanju21 | Solid State | 10 | 24th April 2012 09:03 AM |
| Wildcard Power Amp dev. thread (SMD, Quasi NMOS, IRFP260, digital bias) | danfo098 | Solid State | 2 | 16th May 2011 08:57 PM |
| NMOS 350/500 by Quasi | ID_ | Solid State | 113 | 13th February 2011 02:37 AM |
| ..About quasi class a bias for a headphone amp.. | ljordan | Headphone Systems | 2 | 17th May 2005 04:19 AM |
| My new 1000W PA amp (pic post) | matth | Solid State | 78 | 27th October 2003 09:23 AM |
| Page generated in 0.12829 seconds (78.84% PHP - 21.16% MySQL) with 11 queries |
