Old 2nd July 2011, 02:42 PM   #1
gto127 is offline gto127  United States
Default Poor bass in Yamaha receiver
I've been working on a High end Yamaha receiver lately & can't seem to figure why the bass is thin. I've eliminated setup issues. In pure direct 2 channel mode same problem. So far I've replaced output bypass caps and resoldered poor joints in powerr supply. I think whatever the problem is may be common to the brand. I was searching AV forums and many Z11 owners had poor or thin bass while others had superb bass. Most Yam receivers I've heard do have very good bass so It's got to be some type failure in some units. If anyone has ran across this in other Yam units with solution it would be appreciated. I've notice the amp sections on these units are almost identical across most models.
Old 2nd July 2011, 10:37 PM   #2
nigelwright7557's Avatar
If the amp has any age then I would suspect any electrolytics.
They dont cost much so worth replacing them all.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Yamaha R-5 Receiver Shamron Analog Line Level 6 29th August 2011 05:36 AM
Poor bass in Yamaha receiver gto127 Solid State 0 2nd July 2011 02:35 PM
Poor bass from my 10"s damosas Subwoofers 12 15th September 2009 10:22 PM
Poor bass extension from small vintage ARs... Help needed! Kuja Multi-Way 4 4th July 2009 01:11 AM
Gainclone LM4780 (poor bass ?) nickthevoice Chip Amps 66 31st March 2007 11:36 PM
Page generated in 0.06922 seconds (72.20% PHP - 27.80% MySQL) with 10 queries
