Is it possible to do a THD vs output power graph in LTspice in any way ?
Anyone knows ?
The point of life is to build atleast one audio amplifier before you die. |
#2 |
#3 |
Here's a file...maybe you've already done this, in which case, my apology for the redundancy. A typical kind of amp, and I sweep the drive level. If you look in the Spice error log file (view=>spice error log), you see the output distortion.
I know you wanted a graph, but maybe this is a useful stop along the way. unzip the model file and the .asc file into the same directory, and run the test case. |
#4 |
The enclosed zip file contains a pdf file that describes what's going on in the enclosed LTSpice files.
In a nutshell, it lets you make plots of THD versus input level in LTSpice. Given this example, you could probably also do THD plots versus frequency, but I haven't tested that. I thought I'd get feedback on the original question first before continuing. I hope this is useful, and clearly enough documented to be understandaable. Feedback is appreciated. Dan |
#5 |
nice thanks....
#6 |
In bob cordell's book he specifically uses LTSpice for distortion simulations. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#7 | |
I have the level stepped and can see both my fourier and error log total THD , therefore I can see the data I need (below 1). It would be a lot of work just to get a handy (level vs. THD graph). It seems a shame , as I have the total THD data stepped in the log , that it could not be directly plotted out versus the stepped levels.OS The FFT with multiple steps shows the progression of H2 -9 as output increases , which is still quite useful.
Mongrel website , always current and updated : http://67.248.209.21/D%3A/WEBSITE/ |
#8 |
One more link to solution LTSPICE THD Analyzer
Audio Perfection |
| LTSpice way too high input sine wave THD | Neutrality | Software Tools | 8 | 17th May 2011 02:53 AM |
| LTspice model for Dynaco A470 Output Transfomer | Ray Waters | Tubes / Valves | 5 | 17th February 2011 03:33 PM |
| THD in LTSpice ? | Tekko | Solid State | 74 | 30th November 2010 01:37 PM |
| OT: how can I measure THD of my amplifier if my sound card is 0,02% THD ? | ygg-it | Solid State | 1 | 13th June 2010 07:54 AM |
| LTspice tool for power amp power supply component evaluation | andy_c | Software Tools | 2 | 23rd August 2009 05:10 PM |
| Page generated in 0.09778 seconds (76.32% PHP - 23.68% MySQL) with 11 queries |
