Old 1st July 2011, 02:47 PM   #1
Question jfet without biasing
I have a strange question:
Somebody tell me that jfet can be used without any biasing in small signal amplifer,so very low noie can obtained.
is it true?
thanks!
Old 1st July 2011, 03:01 PM   #2
The input can bias the jFET to zero Vgs. This requires that the jFET be run at exactly 100% of it's Idss.
regards Andrew T.
Old 1st July 2011, 03:40 PM   #3
So what is the advantage and disadvantage of such method?
Old 1st July 2011, 03:50 PM   #4
h_a is offline h_a  Europe
h_a's Avatar
You mean no source resistor? Sure that's possible, though only for small signals (forward biasing).
Hannes
Old 2nd July 2011, 10:36 AM   #5
satoru is offline satoru  United States
The noise of JFET goes down proportional to the square root of the current. Higher the current, lower the noise. On the other hand, the leakage current goes up significantly higher when the JFET is biased positively. Practically saying, you better limit the positive bias to less than 0.1V to for obtaining negligible amount of leakage current for high gm JFETs. So, in other words, when you have less than 0.1 Vp-p input signal, a zero biased JFET can be used. I have posted a plot of leakage current of positively biased 2SK170 somewhere in the forum. What kind of amplifier are you designing?
Have fun!
satoru
FS: PreAmp with Complimentary JFET Diff input & JFET ouput USAcircuits Vendor's Bazaar 12 21st June 2011 11:02 AM
Can I replace BF245C JFET with J201 JFET? bigmike216 Parts 2 7th December 2005 06:50 AM
low-biasing or high biasing in Class-AB amps Workhorse Solid State 124 18th October 2005 04:45 AM
Biasing Wyatt Turk Tubes / Valves 10 1st October 2004 02:11 PM
Page generated in 0.07071 seconds (69.45% PHP - 30.55% MySQL) with 10 queries
