Old 29th June 2011, 06:57 PM   #1
Default Optocoupler Speaker Protection
can someone please check this circuit over before i order the parts,
it should short out the power supply rails of the amp if dc in on the speaker output.
Old 29th June 2011, 07:09 PM   #2
Bensen is offline Bensen  Belgium
Bensen's Avatar
You are using a diac with a breakover voltage of 32V? This seems a factor +-60 to high in my eyes.
The Ulti Amp from Elektor uses the same idea to shortcircuit the rails. They have shorted the rails to the ground.
See post #4
Elektor's "Ulti Amp"
Gr.
Old 29th June 2011, 07:22 PM   #3
Do you know a substitute that has a lower breakdown voltage?
Old 30th June 2011, 06:28 AM   #4
Mooly is online now Mooly  United Kingdom
Mooly's Avatar
What if the offset is negative ? The LED in the triac won't conduct.
Also DC offset protection should trip even with a low offset of only a couple of volts or so.
A simulation free zone. Design it, build it, test it.
Old 30th June 2011, 11:43 AM   #5
Is this better?
Old 30th June 2011, 03:22 PM   #6
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Originally Posted by benproiii View Post
Is this better?
I think conceptually it will work, but I'm not sure the switch-point is well defined. You don't want it to switch unnecessary.
What is the threshold voltage of that bidirectional thing?
There's also the real chance that one rail fuse blows before the other, and you end up with one rail active and that's probably worse than the offset.
If you do it this way, use two triac one for each rail to gnd.
jan didden
/Another new issue: Linear Audio Volume 3!
Old 30th June 2011, 04:38 PM   #7
how bought this?
speaker protection audiofan Solid State 0 19th February 2009 02:35 PM
Speaker protection help ronjodu Chip Amps 9 16th July 2007 11:49 PM
speaker protection (OR) overload protection myanmar Solid State 7 13th July 2006 08:21 AM
FS: Niles HDS-6L speaker selector w/ speaker protection. Spasticteapot Swap Meet 0 27th May 2006 11:14 PM
Speaker protection Dominick22 Chip Amps 56 12th March 2006 12:32 AM
Page generated in 0.12073 seconds (66.99% PHP - 33.01% MySQL) with 11 queries
