Old 29th June 2011, 02:52 PM   #1
ljm_ljm is offline ljm_ljm  China
Default NEW DESIGN L 150W FET AMPLIFIER
This is my new design of a level after amplifier.
It adopted VISHAY company produces the IRFP240 MOSFET. Each track six only.
This is a focus on low distortion of amplifiers, circuit structure asymmetrical sent fraction circuit. And must complementary structure.
After several times of modification and test. Main improvement is the reliability problems.
Now output can achieve + 65 V sine wave and good work.
Old 29th June 2011, 03:38 PM   #2
astankov's Avatar
PCB is good but can we see a schematic?
Old 29th June 2011, 04:23 PM   #3
Can. But I hope that this circuit is used only for reference. Because of the different parts will have to change some of the circuit structure.
I try to use different parameters.
In addition. The circuit structure similar to MK2 mosfet amplifier.
Old 30th June 2011, 01:06 PM   #4
astankov's Avatar
I think Q11 is connected in wrong way on the schematic isn't it ?
Old 30th June 2011, 02:43 PM   #5
Sorry. Because I use of the pipe and software packages of different, just to from already the design is convenient.
In fact is different.
Old 30th June 2011, 03:28 PM   #6
Only as a reference for circuit.
In the actual test is more effective method.
Old 30th June 2011, 05:24 PM   #7
NMOS is offline NMOS  Germany
NMOS's Avatar
Ok this is quasicomplementary circuit, did you in your amp test symmetrical clipping ?
often quasicomplementary amps dont have symmmetrical clipping
Transistor Q20 is good solution, did you test this amp in real load condition and is it stable working ?
Old 30th June 2011, 06:40 PM   #8
Boscoe is offline Boscoe  United Kingdom
Did you make this board is it the the final revision?
Is there already a place to get them?
Is there someone selling these LJM designs on ebay?
I thought about it once, but then thought again.
Old 30th June 2011, 06:51 PM   #9
Pretty similar to the last mosfet amp i made, only major diff is the "upside down" PNP LTP. Transistor Q20 seem to serve the same function as the baxandall diode.
I had the same number of mosfets but got 214 watts continous unclipped into 4 ohms.
The point of life is to build atleast one audio amplifier before you die.
Old 30th June 2011, 08:13 PM   #10
Dis you design it? Have you got any info on it?
150W MOSFET Amplifier with IRFP250x2 apexaudio Solid State 127 31st January 2012 08:22 AM
Threshold FET 10/pc Phono Stage Preamp Schematics aka FET 10pc, FET-10pc, fet ten/pc krellkraver Solid State 1 8th February 2007 03:05 PM
fet amp design revamp unclejed613 Solid State 2 14th January 2007 08:26 AM
Fully complementary FET-in FET-out design Bensen Solid State 36 7th January 2006 09:21 AM
My new 150W R2R design! amplifierguru Solid State 28 11th August 2005 04:11 AM
Page generated in 0.13094 seconds (67.48% PHP - 32.52% MySQL) with 11 queries
