Last week after some cleaning done on this old amp I decided to do the bias adj following what has stated in the service manual. I bought this used and the left channel sounded a bit unclean. It is otherwise ok.It turned out I managed to fry all output ransistors and then some. So,tonight,I have all of them replaced and started measuring.I connected to the test point next to VR5 and noticed the voltage reading is much higher than what suppose to be. 0.4v to 0.4mv. And VR5 is at min(highest resistance). I am thinking some resistors might be bad. I would appreciate advices on this matter and thanks in advance.
#2 |
Ok. So after some testing on resistors and transistors I've found some of them are bad.Ao that's a good start.Although I wondered what cleaning steps will cause the output transistors and related components to burn.
| Denon POA 2200 - TO LOW IDLE CURRENT | silversweden | Solid State | 14 | 27th August 2011 06:43 PM |
| help setting up idle current | lensmanMk2 | Solid State | 31 | 10th March 2010 11:48 PM |
| chip amp idle current | maylar | Chip Amps | 2 | 29th December 2004 03:25 PM |
| SMPS Idle Current | cm961 | Parts | 2 | 20th February 2004 05:56 AM |
| Page generated in 0.06580 seconds (61.67% PHP - 38.33% MySQL) with 10 queries |
