Basically I want a nice powerful amp. I'm currently using a real old sony receiver which is not nice. It provides lacking non existant bass but sounds very forced and un-natural when the eq is tweaked. Mid range is again lacking although there and sounds muddled, highs are nice althoug hperhaps a little overpowered.
So now I want a great sounding amp like my old akai but with a bit more power! These are my must haves and I would love to see the diy community point me in the right direction! -200Wrms into 8ohm at low distortion. -No TO-3 packages due to the design. -Pre made PCBs available with a good supply of info on it. -Parts available to the UK. The GM clone in the group buy has some PCBs avalible but only in TO-3 but I think due to my requirements I might have to compromise. What does this amp sound like? Good? Thanks.
I thought about it once, but then thought again. |
#2 |
Lack of bass sounds like dried up capacitors and mabe the speakers either beein incapable of producing the wanted amount of bass, needing more power than ur amp can supply or simply just beeing placed so that your listening position is right in a node where direct and reflected sound is cancelled out, leaving mostly higher freqs behind.
Sounding forced could indicate either excessive cone movement, a clipping amplifier or a faulty amplifier such as dried up caps.
The point of life is to build atleast one audio amplifier before you die. |
#3 |
the 2SA1295 2SC3264 are the transistors you need if you want high power and no TO3 package.
maybe you can make an amplifier with TO3 transistors and replace them with MT200 transistors? |
#4 | ||
| Need some advice/help on a two way build. | Boscoe | Multi-Way | 5 | 28th March 2011 10:01 PM |
| Need some build advice... | Boscoe | Multi-Way | 0 | 7th December 2010 06:49 PM |
| First sub build advice | dholcombe | Subwoofers | 1 | 16th June 2010 05:03 AM |
| Looking for some build advice | JPeitzman | Tubes / Valves | 8 | 8th June 2010 05:10 PM |
| Page generated in 0.07417 seconds (80.90% PHP - 19.10% MySQL) with 10 queries |
