Old 27th June 2011, 10:27 PM   #1
jez is offline jez  United Kingdom
Default Any links to "Are Op Amps Really Linear?" by Barrie Gilbert?
The links for the article are all dead.... Does anyone know of a working link or maybe could email me a copy?
Repairs and mods to Real Hi-Fi, guitar amps and P.A. in North East England. http://www.arklesselectronics.com
Old 28th June 2011, 01:22 AM   #2
jcx is offline jcx  United States
Analog Avenue: Are Op Amps Really Linear? (6/10/98) <META NAME="DESCRIPTION" CONTENT="CMPnet's network of technical information for the Electronics Professional, including EETimes, EDTN Design Center, Electronic Buyers News and Semiconductor Business
text, but the drawings aren't available
the analysis is correct in context - but not relevant to modern audio op amp application given the availability of much higher GBW - the input tanh distortion % drops as the square of the ratio of signal frequency to GBW
it is quite practical to use 50x higher GBW op amps than Gilbert's example - giving 2500x less of the distortion he discussed
the article is also misused by John Curl as "evidence" that Otala's PIM theory and "flat open loop gain" over audio frequencies acquired a new "convert" - not so - just read all of the article, not selectively as Curl has
the search may also lead to some of Walt Jung's early articles - he did initially embrace the "flat gain" prescription from Otala but in later publications came to the correct conclusion that one can have high loop gain/low corner frequency and still have low PIM
Marshall Leach also traveled the same intellectual path - ultimately rejecting Otala's "flat loop gain" over audio frequency as being a necessity for low PIM
High loop gain (and high GBW), 2-pole compensation,
input stage linearization techniques including local degeneration, "cascomp", FET inputs, or Gilbert's multi-tanh compensation (now available in some AD op amp) all change the conditions of Gilbert's article analysis
Old 28th June 2011, 10:21 AM   #3
Thanks very much for the link jcx! I'd looked all over the interweb thingy for that....
Modern high bandwidth op-amps do indeed ameliorate these issues greatly.
In spite of the "proof" of the authors you mention (and also Cherry, Self and our own Bob Cordell who all seem to agree with the anti Otala/Lohstro line) it feels somehow intrinsically right to have a flat open loop gain to beyond audio frequencies before applying NFB.
Old 28th June 2011, 10:39 AM   #4
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Originally Posted by jez View Post
[snip]In spite of the "proof" of the authors you mention (and also Cherry, Self and our own Bob Cordell who all seem to agree with the anti Otala/Lohstro line) it feels somehow intrinsically right to have a flat open loop gain to beyond audio frequencies before applying NFB.
Look at it this way. Take an amp with a flat OL gain of 50dB from DC to 30kHz. Certainly one that you would approve of I assume.
Now increase the OL gain at 30Hz to 80 dB, and then roll it of so it gets to the same 50 dB gain at 30kHz. (Leave all other things the same of course).
This amplifier has more gain at lower frequencies and for the same closed loop gain has better linearity at all audio frequencies. If the first amp was TIM free, so would the second amp. Yet, because the shape of the curve doesn't look right for you, you would not approve of it? Where would you base that on?
jan didden
/Another new issue: Linear Audio Volume 3!
Old 28th June 2011, 11:57 AM   #5
Gilbert's multi-tanh compensation (now available in some AD op amp).
Which opamps?
Samuel
Old 28th June 2011, 12:35 PM   #6
jan didden
I'm well aware of the theory Jan
Doug Self takes that one to extremes!
It just "feels right" for the open loop gain to be reasonably flat across the audio bandwidth.
It becomes a real problem when amps have loads of OLG at very low frequencies like 100Hz but are rapidly running out of gain at high audio frequencies and a bit beyond.... Just where we need it for the NFB to be effective in reducing the higher order artefacts of crossover distortion.
The situation you describe of course doesn't suffer from this but I've seen far too many that do.
I'm with John Curl on this one
Old 28th June 2011, 12:41 PM   #7
SY's Avatar
And yet, when you look at the THD versus frequency of nearly any half-decent amp (I'll exclude "designer" high end gear, which is often poorly conceived), you don't see an enormous rise near the high end of the audible range. IM, same deal. Looking at distortion residuals, the crossover distortions of most commercial gear are minuscule. So the theory does work in practice, "feelings" and 1968-vintage anecdotes aside.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 28th June 2011, 12:50 PM   #8
DF96 is offline DF96  England
Was it Einstein who said that intuition is merely a set of prejudices laid down during childhood? Flat OLG may "feel right", but it is likely to be wrong. One possible get out: if distortion products at high frequency can be made more palatable by the simultaneous presence of low frequency products (e.g. via masking) then flat OLG may sound better. If this is the case then it must be understood that this is an example not of 'better', but 'worse in a more pleasing way'.
Rapidly running out of gain at high audio frequencies is a problem, but it has nothing to do with open loop bandwidth.
Old 28th June 2011, 01:41 PM   #9
janneman's Avatar
[snip]The situation you describe of course doesn't suffer from this but I've seen far too many that do.
Examples, perhaps?
jan didden
Old 28th June 2011, 01:43 PM   #10
Originally Posted by Samuel Groner View Post
Which opamps?
Samuel
AD8099:
John Curl's Blowtorch preamplifier
http://www.google.com.ua/patents/dow...erview_r&cad=0
I believe the ADA4898 also uses the same input stage linearization - closer reading suggests it isn't strictly Gilbert's multi-tanh input but gives a related flattening of the input gm
Jung/Gallo &quot;LT&quot; preamp and op-amps... FidPup Solid State 1 25th September 2008 04:41 PM
Linear voltage regulator: how to make good use of "sense" and "ground sense"? NeoY2k Analog Line Level 7 6th September 2008 11:35 PM
Usual problem&quot;Op Amps&quot; aleksandar Solid State 7 9th June 2007 06:13 PM
ANY "High-Perf" SIL op-amps to replace NJM5532 homemade Parts 2 13th December 2006 03:41 AM
Page generated in 0.12740 seconds (79.86% PHP - 20.14% MySQL) with 10 queries
