I am planning to use a stereo cable as an input to my amp and they come in sheilded and unshielded variety, which should I be using?
If my PCB isnt shielded in any way can a shielded connector do anything? |
#2 |
a)Use shielded (and possibly twisted pairs) interconnect cables (I personally like microphone cables such as Bedea 7502BG).
shielded connector does perfectly nothing. Insted of that, shield case.;-) |
#3 |
Depends on the impedance of the source.
If it is the output from a preamp then its likely to be low impedance in which case a shielded cable isnt going to make much difference.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#4 |
output is from an MP3 player so i guess that has a headphone amp, I assume thats low(er) impedance.
#5 |
Location: Lawrence, a nice little college town in Kansas
It can't hurt to use the shielded cable. It may even help, depending on the environment (strength of EM fields) and length of cable. If the cost difference is not big, go with shielded.
| Why shielded tubes | off1 | Tubes / Valves | 7 | 14th November 2010 10:55 AM |
| Shielded transformer | techtrino | Parts | 2 | 28th November 2009 02:43 PM |
| Can I use 4-pin Molex connector as speaker connector? | MikeHunt79 | Everything Else | 5 | 3rd June 2009 07:21 PM |
| Shielded wire | fsjonsey | Tubes / Valves | 7 | 21st March 2008 03:33 PM |
| shielded vs. non-shielded | mytool4u | Instruments and Amps | 12 | 7th July 2005 10:12 PM |
| Page generated in 0.09779 seconds (62.29% PHP - 37.71% MySQL) with 10 queries |
