need help to make right choice psu transformer for 405 clones i have very well made old toroid 2 secondary out 58 v 80 v dc the other 30v ac / 42 v dc out i am not sure of va 3.5 amp on mains 5 amp on psu 400 -600 ? also 2 maplin 35 v sec 42 v dc out 160 va also any advise on psu position respect to amp boards placed each end of amp case the case to be made from white 6mm thick perspex i am new to the forum as you will have gathered cheers bernard
#2 |
sorry wrong specs re transformers 1 secondary 58 v ac 80 v dc on rails 2 sec 35v ac 50v dc out
#3 |
VA rating is very related to physical size. +/- 80V TBH sounds like a recipe for an amplifier blowing up, +/- 50V a lot more reasonable, if they are of similar size, go for the latter as its far more sensible. As its Vsquared/R, +/- 80V is good for 2.5 times the power of +/-50V. the 405 AFAIK simply is not designed for +/- 80V rails. As +/-50V is good for 100W or so, +/- 80V is heading towards 250W. So the latter needs to be far bigger than the former, or it won't work. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#4 |
Hi bdm47,
Just as I was going to post a reply, sreten beat me to it. But anyway, I totally agree, +/- 80v way too high, use the other one. Mike |
#5 |
thanks for you help the old transformer also has sec 30v = 42vdc size w/110mm h 45mm cheers bernard
| Core choice for power transformer | Joshua_G | Power Supplies | 15 | 23rd December 2010 08:19 AM |
| Transformer choice | faxurda | Digital Source | 8 | 7th March 2008 05:02 PM |
| Choice: two Trends T-10.1s or one Kingrex T20 w/PSU | gnostic19 | Class D | 8 | 13th August 2007 06:50 AM |
| transformer choice for amp | Richidoo | Solid State | 27 | 17th April 2007 08:35 AM |
| Transformer choice for LM3875 | Taliesin | Chip Amps | 6 | 18th May 2003 11:40 PM |
| Page generated in 0.11576 seconds (62.30% PHP - 37.70% MySQL) with 10 queries |
