Got a news mail and got a deja vu feeling of having read some similar articles in the past where some "revolutionary" products are said to be "the one and only". Perhapes it has to be this way if we want journalists to tell us (preach) that there are some real expencive products that are going to change our lives if we have got the money and that the new era of perfect fidelity has now reached us? BTW I built a pair of mono blocks without emitter resistors som 25 years ago. I might be a bit cynical but can´t help to ask myself if my not perfect amps are fooling me to enjoy music?
A quote from Jonathan Valin: " I’m told by those who know that the elimination of emitter resistors is a genuine innovation in solid-state design" But here´s the article: Technical Brain TBP-Zero EX Amp & TBC-Zero EX Preamp (TAS 213) | AVguide.
Without wonderment,no life. Last edited by The golden mean; 26th June 2011 at 09:33 AM. |
#2 | |
Emitter resistors are everywhere. Not only in output stage. They are the easy way to control current flow. To remove emitter resistors you need to complicate and this can potentially disturb the amplifier more than emitter resistors does.
lineup |
#3 |
Also, it's just a marketing move. I'm a complete neophyte but i've been reading audio magazines since i was 17 (and i'm 27 now) and i've long learned to just ignore any qualitative claim made in them that is not supported by hard data (measurements etc.).
#4 |
Not only that, but in another thread here recently it was found that the removal of these Re's has been used decades ago.
jan didden
/Another new issue: Linear Audio Volume 3! |
#5 |
Sinclair amps from 1972 Z30 and Z50. No output BJTs emitter resistors.
#6 |
For me and the other non-engineers, the emiter resistor acts like a sort of valve which makes the output transistors all work equaly hard (within the variation of the resistors)???
Would the average class AB be toast if one were to remove these, do we just put these in because of habbit? What dictates the values? |
#7 |
They also help with thermal stability. If you take them out, the amp will often be thermally unstable and run away. Sinclair things were, after all, famous for blowing up
#8 | |
There are already more than enough great sounding amps for DIY, we don't really need any more that offer diminishing returns for the effort and expense.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#9 | |
dado |
#10 |
At 40 years old they are probably the old "hometaxial" 2N3055 devices. These could be used without emitter resistors as the emitter already had some considerable resistance. If you tried it with a modern "epitaxial" 2N3055, it would runaway and blow up.
| what to do with 10"kappa perfect | gmtech1 | Subwoofers | 6 | 8th July 2008 01:58 PM |
| Beyerdynamic's Headzone headphone promise "perfect spatial impression" | Nordic | Headphone Systems | 1 | 28th August 2007 09:10 PM |
| Transient-"perfect" 2nd/1st order crossover | phase_accurate | Full Range | 10 | 10th July 2007 06:49 PM |
| WTB: Focal & Audiom & Volts 11", 12", 13", 15" woofer | gengis | Swap Meet | 0 | 17th March 2005 02:29 AM |
| "transient-perfect" crossover in 12/02 AudioXpress | dorkus | Multi-Way | 41 | 25th November 2002 07:23 PM |
| Page generated in 0.10747 seconds (81.94% PHP - 18.06% MySQL) with 11 queries |
