Old 25th June 2011, 05:52 PM   #1
sekhar is offline sekhar  India
Default NEED A 600W@4E AMP .............WHICH TO START WITH
I was in a need of of a stereo amp 600W + 600W@4E amp for my little pa purpose........
I need to build such a amp for my frnd as he needs it badly.....
I have searched the forum and found a few ...... but i am confused which one to start with .....
1. Apex B500
2. Legend MK2
3. Dirty harry......
4. Amps from quasi ARCK 600....
5. some unnamed amps....
6. some qsc schematics .........
I have to make it there is no option of buying the amp or going to class D as class D is currently out of my capability range......and i dont wanna buy a amp just cause its gonna be cheap........ I wanna do it here and make the best of what we have in the forum............i just a simple powerfull amp with good sonics ..........do add in ur suggestions............as i may have left out many choices......
I wanna make a good pa amp and share it with every one and may be i will even do the smps for the amp if every thing falls right in place....
Some schematics...............
regards
sekhar
Old 25th June 2011, 06:48 PM   #2
lineup is offline lineup  Sweden
lineup's Avatar
Build the APEX.
You get fairly good support of Mr Apexaudio himself.
lineup
Old 25th June 2011, 07:02 PM   #3
mihailo is offline mihailo  Serbia
Hi Sekhar.
I have build and used APEX B500, Quasi nmos350, Legend stage master, all 3 sound good.
B500 is excellent for subs, nice power and gain even without mixete or active crossover.
Quasi and Legend, they sound excellent in live performance parties with instruments, nice mids.
Old 25th June 2011, 08:29 PM   #4
i have also build apex b500 and legend both sounded good ................... i need to redesign the pcb and include all protections in it................
more suggestion would be welcome
regards
sekhar
Old 25th June 2011, 08:34 PM   #5
black is offline black  Romania
Send a message via ICQ to black Send a message via AIM to black Send a message via MSN to black Send a message via Yahoo to black
luck this Forumul electronistilor • Vezi subiect - Module Si Amplificatoare Clasa AB by LECO sound very very good 800w/4 ohms
Old 26th June 2011, 11:38 AM   #6
ATAUDIO is offline ATAUDIO  Austria
regards
sekhar
Yes, protections. Since you said PA that is not an option. So, which protections you are including?
@Audio
Old 26th June 2011, 12:51 PM   #7
@ ATAUDIO
all sort of protections say .......
1. over temperature
2. output shortcircuit
3. dc detect
4. input limiter
5. clipping detector
6. over current detector....
every thing that needs to keep a PA amp alive and kicking for yrs of service..........
i would like to make a one time investment.............. and make the best that is possible...
regards
sekhar
Old 26th June 2011, 12:52 PM   #8
i will be coming up with a schematic shortly ........... most probably its gonna be apex b500 but with slight changes............
regards
sekhar
Old 27th June 2011, 05:29 PM   #9
ok the schematic is some wat ready...............
regards
sekhar
Old 27th June 2011, 05:35 PM   #10
changes to the the b500 schematic............
1. added a regulated supply for the opamp.........no need for big heated resistors.....
2. added a darlington configuration for the o/p so that it can drive many o/p transistor........
other wise the circuit is same ..............
further amendments to the circuits planned are....
1. add a VI limiter......
2. add a step driver ..... if only i can do it...........
comments r welcomed.......
regards
sekhar
Easy-to-build 600W Power Amp OliverD Solid State 39 27th December 2011 05:46 AM
plate amp or diy suggestion for 600w PA sub kevin tyler Class D 0 20th December 2010 06:23 PM
WAT TO DO ??????????? MOSFET OR BJT FOR A 1200W RMS AMP @ 4E phoenix87 Solid State 8 30th September 2010 06:58 PM
searching for a 600w amp project masta Multi-Way 1 30th September 2006 01:45 AM
Page generated in 0.72947 seconds (11.39% PHP - 88.61% MySQL) with 11 queries
