Output Relays
Output Relays
Old 7th April 2012, 02:37 AM   #361
Bonsai is offline Bonsai  Europe
Tip: Switch the speaker ground return line and ditch the opto.
Old 7th April 2012, 09:53 AM   #362
FdW is offline FdW  Netherlands
FdW's Avatar
Output Relays
The amplifier is designed for bridged usage, switching the ground connection is not possible. Why ditch the opto. I am going to use an FOD3120 and thus will have a very simple circuit (no need for the two transistors, and even faster). At a price of about 1.30 Euro's, how would you beat that (price or performance wise)?
Naturally it would be possible to drive the NMos fet's with an very simple circuit (almost non) if you were switching ground.
Old 7th April 2012, 04:12 PM   #363
Even if you are switching a bridged amp,you can ditch opto.
Separatley, I am still trying to understand why you want 4 mosfets in parallel when 1 will do the job better thaany currently available relay.
Old 7th April 2012, 04:14 PM   #364
AndrewT is online now AndrewT  Scotland
I want to ditch opto requirement.
Can you show me the light?
regards Andrew T.
Old 7th April 2012, 05:16 PM   #365
FdW's Avatar
Output Relays
First of all, I did decide to go with 4 NMos devices. 4 x IRFP4668PBF for Rdson around 10 mOhm (Mouser 3.85 Euro/100) http://www.irf.com/product-info/data...rfp4668pbf.pdf
They are 2 by 2 series and parallel giving about 10 mOhm. NMos devices with sufficiently low Rdson and Vds of 200 Volts are not easy to find. When using 10 mOhm devices 2 in series (non parallel) I would get 20 mOhm, and that is about the same as an conventional (good quality) relay (and I want to do better than that in all respects). The other thing is, it is cheap, compared to a good quality relay. I could be using 10 in parallel (for a total of 20) and not even approach the price of a good relay, so why not? Why not improve 'ALL' specs of the mechanical relay, be faster, be more reliable and have a lower Ron!
And I am interested in that non-opto solution just out of curiosity.
Old 7th April 2012, 07:34 PM   #366
Mooly's Avatar
Output Relays
Unless I'm missing something it's easy because the FET's are ground referenced.
It's just a variation of this,
Output Relays
Which seems to work OK as shown here. First pic is switch on. Blue trace is voltage on R/H end of 8 ohm load... zero volts.
Old 7th April 2012, 08:20 PM   #367
FdW's Avatar
Output Relays
Output Relays
But, as I noted, this (referenced to ground) will not work for bridged amplifiers.
Old 7th April 2012, 11:40 PM   #368
djk is offline djk
djk's Avatar
You might be able to move it into the negative supply rail on a bridge amplifier, just a single FET should be OK. The circuit would need a change of origin for detecting DC off-set and removing the FET drive.
Candidates for the Darwin Award should not read this author.
Old 8th April 2012, 05:46 AM   #369
Mooly has it. But I used a slightly more complex drive circuit. I will post something up later today if I remember. For a bridge amp, you would have to reference accross both the supply rails.
Old 8th April 2012, 08:26 AM   #370
Mooly's Avatar
Output Relays
So you move your reference point.
Yes, and in the example here which seems to work OK you need to be able drive the fet gates to higher than the positive rail. Or more correctly to maintain at least the Vgs required to keep the FET on. I left the drive at plus 50 volts to show the "clipping" that occurs if you don't. Change V3 to 55 volts and the clipping goes. In practice it's easy to arrange a sub PSU rail with a voltage doubler to get a higher rail.
Green trace is V2
Blue trace is other end of 8 ohm load
In the second pic the blue trace is overlaid on the green showing no voltage across 8 ohm.
Output RelaysHide this!Advertise here!
Leach amp - need suggestions for output relays velicko Solid State 15 16th April 2011 10:55 AM
how to install more relays? scampo77 Construction Tips 17 28th October 2009 07:17 PM
Reed Relays Vs Standard Relays steevo Solid State 9 21st September 2009 06:08 AM
Relays or switches chalkandtalk Solid State 17 9th September 2007 09:05 AM
Relays for Alpeh P 1.7 Miles Teg Pass Labs 1 6th September 2001 10:49 AM
