#281 |
If used as supply rail switches and particularly if there is a significant rail capacitance to charge then yes, I suppose SOA could be compromised depending on the device chosen.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#282 | |
The AVAGO data sheet I have for the ASSR-621 does say that the cells can be connected in series. I think for a speaker relay there is no issue at all with both on and off times. I went for series connection to maximise gate drive voltage to ensure lowest possible Rds of the FET's
#283 | |
#284 | |
I remember when I bought my first motorbike, it was a fuel injected 1000cc job. The dealer told me to take it out and give it a good flogging to run it in. I felt insulted by what he had said, firstly; because he put my life in danger, and secondly; because my Dad told me to take it easy for a while and change the oil frequently. I told the dealer he was wreckless and that his attitude stunk, to which he replied "Listen mate, you don't have a dog and bark yourself". Running a powerful amp is an exercise in self control, but as human beans we are flawed, and when we think no-one is listening, we sneak into the lounge, crank up the stereo, pick up the nearest stick and play air guitar. Now dont you? Getting back to the dog analogy; I think we have to be honest about why we like big amplifiers & contrary to what the psychologist will tell you, I believe it has nothing to do with compensating for an inferior anatomy. I reckon that I have a big stereo because I like to play loud Acoustic-Blues music, and if I am to be completely honest I must admit that I want other people to listen to my music too. Sorry I'm drifting off the subject a bit; So I will make my point in one sentence: If you have bought or even built a big amp, then you are going to test it out. It's better to have all the protection you can get because as builders we know how heart-breaking this kind of failure is - not to mention the shame. I would like to encourage you to continue with your project and personally wish you all the best. You may be on the cusp of something big - who knows! I really like your philosophy on the virtual implementations of amplifier circuits. Good luck - Phil Elliott |
#285 |
Hi farmerjack61,
Thanks for the kind words but it's hardly "my project"... I can't take any credit for the idea of using photovoltaic couplers. In fact for me this guy got the ball rolling, and I had always intended to come back and look at the idea further. MosFet Relais And then Michael Bean mentioned the couplers... and the rest is history. (The testing was the results I posted earlier today on the on/off behavior
#286 |
For a new amp design where the SS relay might as well go into the gnd return from the speaker - how would you implement this ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#287 | |
We love our 'home-brew' amps - Just like a mother loves her baby - It's all a matter of perspective. PS Are you named Bigun because you're a largish man or because you have a Big Gun, or perhaps both? The latter would be handy whilst wrestling angry Moose up there in the frosty places. Cheers and bye for now. Farmerjack |
#288 |
This is the schematics that I have developed. It works well, without problems. It is supplied from center tapped secondary of the main transformer, in my case it is 2 x 42Vrms, but would work both with lower or higher voltage. I can post photos and PCB, if someone is interested.
#289 |
Very nice Pavel.
So you are using the opto to turn off the FET's. I'll have to think about this one Does it allow max voltage swing from the amp to be passed OK (gate source voltage maintained as output rise)... it's a bit early in the morning here... Nice one
#290 |
It reduces voltage swing very little, like 0.5Vpeak. I have a lot of measurements, will return later in the day. This is the clipping of my amp with this protection circuit:
| Leach amp - need suggestions for output relays | velicko | Solid State | 15 | 16th April 2011 09:55 AM |
| how to install more relays? | scampo77 | Construction Tips | 17 | 28th October 2009 06:17 PM |
| Reed Relays Vs Standard Relays | steevo | Solid State | 9 | 21st September 2009 05:08 AM |
| Relays or switches | chalkandtalk | Solid State | 17 | 9th September 2007 08:05 AM |
| Relays for Alpeh P 1.7 | Miles Teg | Pass Labs | 1 | 6th September 2001 09:49 AM |
| Page generated in 0.11657 seconds (82.18% PHP - 17.82% MySQL) with 11 queries |
