so, over the past few days i've been looking for the ultimate discrete small signal buffer, and i've found that many of the more promising designs are composed of complementary components, such as a JFET source follower with a CCS or two different buffer circuits merged to bring out the best of each individual circuit. low input capacitance design considerations are made in most of the designs i've considered, but i've found ZERO designs that aim for low output capacitance while fully decoupling DC from the output. i'm thinking this could be accomplished with a trafo, any other thoughts?
oh, and heres a basic list of design constraints, just so i don't keep babbling -very low C-out -must be discrete (no opamps!) -output Z less than 10k ohms -may be active buffer circuit or passive add-on -intended to drive cables that have high capacitance -if active it has to run off 18 volts or less -if active it must have no more than 2 active components (transistors) -my design constraints aren't set in stone. if you think a minor exception will yield a significantly superior result, then thats ok, but NO OPAMPS! thanks in advance |
#2 |
If one measures, by immittance meater, an output impedance (Zout modulus and phase angle) of any correctly designed and assembled schematics, at 1 kHz it is usually close to being active (pure resistance) with rather small phase angle. If the phase angle negative, then Zout has some capacitive component, if positive - then inductive component.
Measured Zout has nothing to do with presence/absence of the output cap/trafo in the schematics. |
#3 |
If you invent an output buffer with capacitive output impedance behaviour at high frequencies, please let me know. It would greatly simplify stability issues with amplifiers...
The output impedance of buffers becomes inductive at high frequencies. That's the real problem. Output capacitance is neither present in real world circuits, nor would it be a problem usually. Samuel |
#4 |
oh i see. i was hoping that a low output capacitance would help with cables that are designed with low inductance and resistance at the cost of high capacitance. i'll struggle towards the low reactance/inductance high frequency stability buffer design. fortunately ive got all summer to do so
| Need readily available High Voltage, Low Capacitance FET | ThorstenL | Parts | 11 | 7th February 2011 11:01 AM |
| Low-capacitance transformer? | janneman | Parts | 38 | 7th February 2011 08:16 AM |
| Buffer for long cable capacitance | trv | Construction Tips | 10 | 28th May 2010 07:37 PM |
| Anyone found a cable with low inductance and capacitance that would be good for tone | fantasia | Analogue Source | 2 | 27th March 2004 04:02 AM |
| Best low-noise low-distortion buffer? | borges | Solid State | 7 | 9th December 2003 12:40 PM |
| Page generated in 0.08552 seconds (66.93% PHP - 33.07% MySQL) with 10 queries |
