Old 23rd June 2011, 11:59 AM   #1
Default Negative output impedance
I´m contemplating some ideas just for fun. Would you say negative output impedance from an amp would be a good thing? Theoretically, if matched correctly with the voice coil resistance it could be used to cancel out the resistance and obtain a very good damping factor, right?
Or is it wrong to assume that the voice coil resistance should be added to the amps output impedance, effectively ruining any small benefits from lowering the amp output impedance to zero?
Old 23rd June 2011, 12:11 PM   #2
Speaker manufacturers usually want that their products would fit into a standard situation - amp's output impedance is close to zero. Providing negative Zout will not guarantee that sound will be better, anything could happen, but improvement is hardly expected.
I would love an opposite idea - trying a transconductance amp (Zout is rather high, near 40 Ohms as tested by Nelson Pass). Some speakers sound excellent under such conditions.
Old 23rd June 2011, 12:23 PM   #3
The maximum power transfer is achieved when the output RESISTANCE is equal to the speaker one and the output REACTANCE is opposite sign and equal with the one of the speaker.
Old 23rd June 2011, 12:33 PM   #4
sregor is offline sregor  United States
I disagree - I was taught that maximum power transfer is achieved when the LOAD resistance = source resistance - for a modern amplifier this would mean the lower the resistance, the more power transferred which agrees with what I've seen in the real world. my 2 cents
It's also getting away to the OP original query.
Steve
Old 23rd June 2011, 12:45 PM   #5
The question here is not about optimal power transfer, it is about best sound quality from the amp-speakers system. And speakers are usually designed and tested with some real amp, having 0,01...0,1 Ohms Zout modulus.
Old 23rd June 2011, 12:54 PM   #6
Those who know how to use the search function
1) wouldn't need to open a new thread and
2) would find a lot of interesting answers
Charles
Old 23rd June 2011, 03:19 PM   #7
Charles
Well, sorry for being such a pain.....
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 05:17 AM
Current Mirror with negative output impedance rtarbell Solid State 3 27th June 2006 08:19 AM
Gainclone with negative output impedance Circlotron Chip Amps 16 10th September 2003 10:54 PM
Page generated in 0.09942 seconds (68.92% PHP - 31.08% MySQL) with 10 queries
