Hi everybody,
I'm trying to fix a guitar amp from Randall, RH-100 G2. Schematics is attached. Some transtistors in the power amp were burned. I replaced Q8, Q11, Q12, Q13, Q14, Q15 (!), D5, D7, R22. I tested (with a simple tester...) the remaining semiconductors and they apparently are ok. After the replacements the amp is in part restored. It 'almost' works in the sense that it sounds quite low in volume and always distorted. I noticed that Q7 and Q9 are heating up a lot. I measured 47V between Q9's emitter and ground and 0,2 V between Q8's emitter and collector. I think this is not normal. Any help or suggestion? Thank you so much! Regards! Giorgio |
#2 |
it could be that any of your balast resistors is open and you missed it check R14-15-16-17....check also R26-25
then check or remove temp. the vi limmiter section ( it will be enough to remove Q10-11 ) to make sure that the drive is free from the limiter in case you have any trouble there
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#3 |
Thank you! I'm going to try.
What's the function of Q8 and Q6, in your opinion? I figured out that Q8 sets the bias for the drivers, depending on the temperature (Q8 is mounted on the same heatsink as the power amps Q12.. Q15). And what about Q6's function? I definetely miss some theory... Thanks! Giorgio |
| RH ECL86 Amp: Dave? | pjanda1 | Tubes / Valves | 11 | 8th January 2012 08:44 AM |
| looking for Randall RH 100 G2 schematics | giokat | Solid State | 2 | 24th May 2011 07:30 AM |
| Randall RGT 100 Amp Problem | GF33 | Tubes / Valves | 5 | 4th May 2010 02:47 AM |
| Counterpoint SA-100 Fix | genther | Solid State | 2 | 11th April 2010 02:57 AM |
| RH-84 Hum | ThSpeakerDude88 | Tubes / Valves | 13 | 8th October 2009 04:48 PM |
| Page generated in 0.08157 seconds (69.68% PHP - 30.32% MySQL) with 11 queries |
