Old 23rd June 2011, 01:05 AM   #1
Default P channel jfet preamp circuit
Gentlemen
this is a JFET n channel pre amp circuit...
Lets say I want to change it to a P channel JFET pre amp circuit. how would I do that...reverse polarity and swap resistor r3 and r2??
Old 23rd June 2011, 06:32 AM   #2
lineup is offline lineup  Sweden
lineup's Avatar
yes.
Basically I think you do right with that.
(even if I can see no circuit)
lineup
Old 23rd June 2011, 10:26 AM   #3
Without seeing a schematic, I think a safer rule would be to swap the polarity of the power feed and swap all semiconductors to opposite type. eg N to P, pnp to npn, diode/zener diode pointing up to diode pointing down, etc.
No resistors need changing, except that the semiconductor parameters may be sufficiently different that requires a small change in resistor value to bring the circuit back to design currents/voltages.
regards Andrew T.
Old 23rd June 2011, 10:44 AM   #4
Here's the schematic for the n channel JFET pre amp. to change to P channel...reverse the polarity and...
Swap resistors r3 and r2? or no?...Where does C1 go?
thanx for your replys
Old 23rd June 2011, 10:51 AM   #5
swap the power feed polarity.
swap to a Pchannel jFET.
swap the two Zeners around (they end up looking exactly the same.
Swap the direction of C" (the polarised cap must be inserted to suit the reversed polarity.
job done.
Do NOT move or change any other components.
I do hope that C1 is chosen for sound quality vs budget.
regards Andrew T.
Old 23rd June 2011, 11:53 AM   #6
SY's Avatar
You don't have to swap the Zeners around.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 23rd June 2011, 02:13 PM   #7
swap the two Zeners around (they end up looking exactly the same)
That's what I said, but the "rule" is to swap all semiconductors. Far easier if there are no exceptions to be listed nor remembered.
regards Andrew T.
Old 24th June 2011, 02:08 AM   #8
Thank you all....I bought some 2sj74 jfets and put them into aleph j boards...firing up circuit, the mosfets bias up correctly but no gain...so I am wondering about the 2sj74's and if they are genuine...I will put one in the pre amp circuit and see it provides some gain in that circuit...if it does, then I have an error in the aleph j build...
Old 24th June 2011, 09:48 AM   #9
Can we do the same thing with front end of BA2 power amp?
Old 24th June 2011, 11:16 AM   #10
lineup's Avatar
You probably have an error in Aleph J setup.
Check the circuit around those 2SJ74 - feedback resistors ....
lineup
FS: PreAmp with Complimentary JFET Diff input & JFET ouput USAcircuits Vendor's Bazaar 12 21st June 2011 11:02 AM
dual N Channel Jfet eapavant Parts 2 8th February 2008 07:10 AM
JFET in-circuit matching Leolabs Solid State 5 9th April 2006 01:44 PM
High voltage (>60V) P-channel JFET? PanzerLord Solid State 15 11th December 2003 12:58 PM
jFET input ,full symmetrical class A circuit promitheus Solid State 28 20th November 2003 06:12 AM
Page generated in 0.12069 seconds (63.65% PHP - 36.35% MySQL) with 11 queries
