Old 22nd June 2011, 04:07 PM   #1
Default In need to solder!!
Hi all, can you please suggest your best kit amp to build.
I'm looking to build a good-sounding 2ch. amp that does around 75-100W/ch. I prefer not chip-amp. Fets and bipolar are OK to me.
I've been struggling on this forum to find an answer by myself but there are as many projects as forum users, I got totally overwhelmed.
I don't exclude building amp clones (Quad, Naim, etc.) Preferably the amp PCB should be readily available. I don't mind having to find invidual components.
I've found my way to the speaker protection circuits, the power-supplies, the soft-start circuits, etc. Only the amp boards/circuits confuses me... too much designs!
As for the money i'm ready to spend... we'll say max 200 (USD) for board and components for both amp boards (AKSAs are eliminated ). I know that all that's around (power supplies, case, etc.) can cost double of that. I'd like to keep the total under 400-500
I want to actually solder things soon.
Thanks for your input!
Martin.
Old 22nd June 2011, 05:02 PM   #2
Bigun is offline Bigun  Canada
Bigun's Avatar
If you are OK finding parts then all you really need is a pcb for a proven design (unless you fancy making a pcb?).
I'd suggest the DX amplifier for starters with lots of threads on this forum. Outside of the forum check out Rod Elliot Sound Products.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 22nd June 2011, 05:27 PM   #3
digits's Avatar
Its a shame you can't do the AKSA's, awesome work supported by an awesome guy.
Old 22nd June 2011, 05:51 PM   #4
ostripper's Avatar
Default go cheap ....
Instead of going the usual route -
#1 - Scan Ebay for $20-40 used pro-amps and certain OEM's. Correlate your biddings with a google image search. Many times you can get a look at the insides. Look for amps that have centered power supplies with external side mounted heatsinks. If you can land one , even if in need of repair , you will have the case w/ heatsinks , a sizable trafo , input/output connectors.
I just spent $90USD for a altec lansing 2240 and a sampson sx1200. I now have 2 cases with 4 huge heatsinks , a 1kva R-core 46-0-46V trafo , a 800va 50-0-50v toroid , 2- 50A bridges , 4 pair working mj15024/25 output transistors , and 4 pair working 2sc5200/1943 OP's (sampson had a blown channel).
ALL FOR $90usd !!!
#2 - Don't reuse the caps unless the amp is new. Apex jr. has real good 63-100V power supply caps. Feel free to reuse most of the semi's , the pro- amp's use the best (no fakes).
If you have the right case style , most ebay cheap power supply/capacitor bank kits (lots of them for $20-30 will fit right in.
#3 - The amps - you can make your own , $90 for a HP laser printer , sprint layout and some fr-4/hcl-h2o2 - done. I just made the power supplies for both the above amps in an hour (below) , pcb uses the APEX capacitors or any 10mm snap-in.
Order any semi's from mouser/digikey (no ebay - fakes). Use the excellent NJW ON semi line if you want a $20 output stage.
You can not beat this system. After I sell the sampson .. I actually will make over $100 and have my DIY amp for FREE !
PS- If you must buy the ebay kits (amp wise) some of the fully complimentary (leach amp) types are "usable" , repopulate with ONsemi devices and mouser nichicon/panasonic parts - good to go!! The kits are so cheap , I just buy them for the boards and any reverse engineering opportunities.
OS
Mongrel website , always current and updated :
http://67.248.209.21/D%3A/WEBSITE/
Old 22nd June 2011, 07:06 PM   #5
lduarte1973's Avatar
naim clone | eBay UK
Old 22nd June 2011, 07:16 PM   #6
ostripper's Avatar
Default BIG stuff....
I have to add - get the "big stuff" done first. Get the case/PS , with lots of room. You will be able to swap a few amps out before finding one that pleases you. The amp/PCB is the lowest priced part of the DIY equation. Most of mine cost just $15-30 apiece , about the same as a full ebay kit (but with better parts - mouser/on semi).
OS
Old 22nd June 2011, 07:34 PM   #7
Bigun's Avatar
Agreed.
Old 22nd June 2011, 07:41 PM   #8
scott17 is offline scott17  United States
scott17's Avatar
The SKA amps get some great reviews: SKA - Simple Killer Amplifier by Greg Ball
Single-Ended Tube Amp Kit
Old 22nd June 2011, 07:47 PM   #9
Bigun's Avatar
Not in the same league as AKSA.
Old 22nd June 2011, 07:57 PM   #10
scott17's Avatar
The OP's original post said that ASKA amps were eliminated.
What makes the SKA devices not in the same league? Please inform me with the details. I am very interested.
Any non Hi-Fi brand solder better than Mcap and Siltech silver solder? mbl Analogue Source 23 24th November 2010 03:13 PM
what solder should be used ?? kambule Parts 27 8th August 2005 01:16 PM
can I solder on this? Duck-Twacy Multi-Way 9 24th February 2004 12:46 PM
how do you solder? theChris Equipment & Tools 15 2nd January 2003 10:55 AM
Solder again Christer Parts 13 6th December 2002 12:48 PM
Page generated in 0.14351 seconds (69.81% PHP - 30.19% MySQL) with 11 queries
