Old 20th June 2011, 03:48 PM   #1
Default Delay Amp power up using a relay.
Newbie learning here.
After months of reading lots of useful information I'm finally doing my first post.
I have a setup like the following:
Preamp -> DSP -> Power Amp
When turning on I'm getting a loud pop from the DSP and another when turning off from the preamp. One of the turn on pops already destroyed a tweeter so I'm trying to delay powering up the amp using a micro controller and relay circuit.
I already built a test circuit based on this with a 12V 3 amp relay but think that the relay wouldn't handle the amp load.
My question is what kind of relay should I get and where could I get it?
Here is what I have:
Thanks in advance
Old 20th June 2011, 06:01 PM   #2
smartx21's Avatar
Send a message via MSN to smartx21 Send a message via Skype™ to smartx21
The Loudspeaker Protection http://www.nabucoeletronica.com.br/d...-schematic.pdf described in this website www-dot-dx-dot-kinghost-dot-net works pretty fine, connecting speakers only after a few seconds since the amplifier has been turned on. And also disconnects speakers immediately after amplifier has been turned off.
We should not dwell on what we do not have, but, instead, be grateful for what we do have!
Old 20th June 2011, 06:15 PM   #3
read ESP. He has published a variety of projects for controlling start-ups and shut downs.
regards Andrew T.
Old 21st June 2011, 02:36 AM   #4
Thanks for the quick replies SMART21 and ANDREWT.
I was hoping to do the relay at the dc stage of the amp board but after reading the pages you pointed it seems that it should be done at the speaker level.
What disadvantage would I get by having the relay before the amp DC input?
B+ time delay relay cbutterworth Tubes / Valves 24 31st August 2011 12:53 PM
Delay relay Alkis Tubes / Valves 5 30th November 2009 06:56 AM
Suitable relay for delay cicuit Nuuk Chip Amps 61 11th January 2009 01:47 PM
Relay delay Ted205 Chip Amps 16 24th September 2008 05:44 PM
Delay-Off relay peace brainerd Parts 7 12th May 2007 03:14 AM
Page generated in 0.06490 seconds (79.02% PHP - 20.98% MySQL) with 10 queries
