All three transistors are available from http:\\Cricklewood Electronics CCTV and Electronic Components and they will post to Sweden.
Be sure to match the hfe group with the originals: O, P, or Y. Also recommend replacing drivers and checking emitter resistor for value. bdent.com has first two, last one out of stock. If you can find exact replacements, no need to change other channel, it is unaffected by the fault. If need to use different replacements, I would for symmetry.
