Still some problems with Crescendo. Oscillation or what?
Old 5th October 2003, 03:22 PM   #41
Eccu is offline Eccu  Finland
Eccu's Avatar
Hi Joensd...
Sorry I don't have better picture than those which are above.
1. Which one is better option:
- I disconnect input cable shield from amplifier board and join that shield with short wire to starpoint or
- I disconnect input cable shield from input socket (RCA) and take wire from input socket ground directly to starpoint?
2. And should I add about 10ohm resistor to that shield?
right way boy... u sold farm and bougth booze
Old 29th February 2004, 10:32 AM   #42
Bensen is offline Bensen  Belgium
Bensen's Avatar
Default Also some problems with Crecendo ME
Hi all,
A few weeks ago I finished my two Crecendo ME amps (only the electronics, no enclosure). I bridged them to drive one speaker of 8ohm. I doubled the mosFET's. I was very happy with the sound coming out of it.
Here is the problem:
Three days ago I plugged the AC power cord in the net. First there came distorted music out of the speaker. And a few seconds later the AC power cord burnt throught.
So, I checked everything, but I didn't found anything suspicious.
I replaced the power cord and plugged the amp back in the net. At first the music sounded good and normal. But then I smelled something. One of the two amps got VERY hot . The 4 mosfet's of one amp were about 80C within a few seconds. The other mosfet's of the other amp stayed cold.
Then I checked all the voltages over the resistors, but everything was fine.
So, I thougt that mine mosfet's were cooked. I replaced them with new ones. But these were alse heating up very fast. So, with the mosfets is everything OK.
Could it be the drivers (mje)? Between the gates off the N and P channel mosfet's I measure 4V. This should be OK, not??
I don't thing the amp was oscillating because the resistor in the zobel network was't hot at all. Also the source resistors were not hot.
Can anybody tell me wat the problem is? I have now idee??
I inserted a new shematic, that's easier to search the problem.
Greetz
Ben
Old 29th February 2004, 11:31 AM   #43
Upupa Epops is offline Upupa Epops  Czech Republic
Replace both compensation caps ( C4 , C5 ) and give capacitor ( M1 / 160 V ) between + / - rails - amp surely oscilated. If you have variac ( regulation transformer ), try start with him - oscilation will be probably depend on rails voltage, so start from zero.
Old 29th February 2004, 12:07 PM   #44
Bensen's Avatar
Thanks for the reply Upupa Epops,
You've said to replace C4 and C5. Probably you mean to replace them with other values, or not? Or do I just have to stick new ones in the amps? Caps like this can't be defect, can they? They are wima FKS caps.
And why is the behaviour off my amp appeared suddenly while he worked fine for about two weeks? The other amp just the same, and this one works perfect ont he same rails.
Greetz
Ben
Old 1st March 2004, 12:35 PM   #45
Bensen's Avatar
Rudy, Joensd, Eccu and other Crescendo specialists
Any more suggestions maybe? Or should I try to replace those caps with new ones?
Ben
Old 1st March 2004, 01:08 PM   #46
I was meaning, that you must give there new ones, not another value, 'cos they may be bad. You can all devices resoldered, 'cos there can be anywhere bad contact. Give surely foil cap between power rails.
Old 1st March 2004, 09:03 PM   #47
wuffwaff is offline wuffwaff  Netherlands
wuffwaff's Avatar
Bensen,
sometimes a fuse just after the ac power cord will help against smoke (or fire) First I would put one in your amp!
Since your amp worked for a few weeks and the other channel is still working I would look for a bad component or a bad solder joint (wich gets worse with every heating/cooling cycle)
william
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 6th March 2004, 05:11 PM   #48
Bensen's Avatar
Hi
I've put a fuse in the AC cord, So that is fixed. I replaced the caps and add a few more caps over the rectifier bridge and over the rails.
I've noticed that the output devices were heating up less fast than before, but still, much to fast when I look at the good working amp.
I think I found one reason that could be the cause of the oscillations.
I build two pcb's for the two amp's. One board with all the output devices and the bias network. The other board contains the diff. input...(voltage amplification)
NOW: those two board are connected with two bundels of three wires. These three wires are: the wire from the amp's output back two the diff input (feedback) and two wires from the drivers to the bias network.
BUT I twisted the three wires together
Could this be the cause???
I recently bought a scope. Is it possible to see the oscillations on the scope? How to measure this, direct on the output.
Thanks in advance
Ben
Still some problems with Crescendo. Oscillation or what?Hide this!Advertise here!
crescendo amp neeraj Solid State 10 22nd April 2012 12:13 PM
ESP P3A oscillation problems Tsuruya Solid State 26 14th August 2008 07:54 AM
Help for the Crescendo ME!! FeFe Solid State 11 14th June 2005 02:56 PM
Problems with Crescendo ME RickIvo Solid State 9 6th November 2003 11:19 AM
Problems with Crescendo ME - Need help! Eccu Solid State 27 13th May 2003 12:43 PM
