Old 17th June 2011, 05:03 PM   #1
sakis is online now sakis  Greece
sakis's Avatar
Default THE PHILIPS 22AH708
ΟΚ ...here is a joke
the schematic attached is the main section amplifier of the philips 22AH708... its an amplifier rated 80Wpc at 8R 52+52 rails and seems to me a japanese design implemented by the european .... so its bootstrap... BC5XX all over but VAS DRIVERS and OUTPUTS are B668-9 2SB 2SD family .... funny i think ...
havent finished repairing it since a f**** open trimmer blown pretty much everything arround the VBE area so i have no listening impressions but there is a thing that got my eye arround the driver area there is a network like a zobel or filter next to the driver supply formed by 10R +47nf film capacitor ...
any comments ????
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 17th June 2011, 08:54 PM   #2
DuncanV is offline DuncanV  Netherlands
This looks like a very typical Philips design.
The R/C network provides improved EMC performance. It suppresses external interference on power rails quite well.
Old 18th June 2011, 09:34 AM   #3
sakis's Avatar
i dont really think that looks like a philips design
the attachment down under is a philps design ...these are the parts normally used in philips designs of te time
Old 18th June 2011, 09:45 AM   #4
homemodder's Avatar
Sakis most amps have such networks, sometimes only a cap is used, duncanV explains it well. I think what looks more strange to you might be the 15 ohm resistors instead, now that you dont see much. Those help to maintain stability of the output section although I dont see why they would be required in a EF, in a triple outputstage those resistors help quite a bit.
Old 18th June 2011, 10:34 AM   #5
sakis's Avatar
corect so far ...seen capacitors here and there seen similar topology in hafler amplifiers
but the philips is a bit more than that and need to see it to understand ...it features piggy boards with ltp vas drivers and vi limiter placed in sort of a mother board to accomodate the output section only ...
There is no other bypass or decoupling elsewhere .... so this network located on the piggy boards next and close to the drivers does all the job
kind regards
Old 18th June 2011, 11:35 AM   #6
Philips's use of Japanese transistors was not that uncommon those days. Also Motorola's MJ's can be found in their 70's and 80's amplifiers. Just have a look at some MFB systems for example.
The 15R tackles the potential risk of resonance, caused by the PSU wire inductance.
Old 18th June 2011, 01:10 PM   #7
Oops, I ment the 10R resistors!
The 15R collector resistors are fusibles, maybe they are there only for safety reasons.
FS Alnico Philips AD3800M AD3800AM and Philips transformers guglielmope Swap Meet 8 10th January 2011 11:28 AM
Philips CD 721 or Philips CD 710 info5 Digital Source 2 13th January 2010 09:22 PM
philips cd 880 philips cd880 service manual 0519 Digital Source 4 28th August 2008 11:43 AM
Which Philips is the best ? Bernhard Digital Source 53 25th September 2007 01:12 PM
Page generated in 0.09973 seconds (72.71% PHP - 27.29% MySQL) with 11 queries
