Thinking about making an amp with separate input stage and output stage boards. Like the attached OPS.
Would make it easy to experiment with different Input stages. Totally crazy? Any drawbacks? |
#2 |
See OS(tripper) He does that!
#3 |
I like the idea and your PCB design (eagle?) . What about thermal compensation/bias adj? And V-I limiting?
#4 | |
It is just an idea for now but I quite like it. Last edited by Neutrality; 17th June 2011 at 06:25 PM. |
#5 | |
About the Vbe transistor, bringing it back to another module with wires, aside that not so "elegant" (complicate disconnection of the boards, etc) is prone to induce oscillations if wires are going to be likely long. Maybe an approach with diodes (Leach-like) is preferable. Anyway Vbe is not an option. So, as usual, a lot of design compromises... But please keep going, I believe your approach is very good! BTW, why "bent" power resistors? Do you want to improve airflow from a fan? |
#6 | |
| PS with boosted rails for IPS, VAS and Pre-Drivers | jkuetemann | Power Supplies | 2 | 29th March 2011 12:12 PM |
| OPS topology | Olivier73 | Solid State | 0 | 19th May 2010 04:19 PM |
| Looking for Aragon IPS (or equivelent) | Jim Leach | Solid State | 3 | 19th May 2010 01:36 PM |
| anyone seen this OPS before? | gain | Solid State | 1 | 14th April 2008 06:39 PM |
| FS: Aragon D2A MKII DAC with Outboard IPS Power Supply | konstantin | Swap Meet | 0 | 17th July 2005 09:03 PM |
| Page generated in 0.09339 seconds (73.15% PHP - 26.85% MySQL) with 11 queries |
