Old 17th June 2011, 10:51 AM   #1
Default current source for class a se amp
First of all : Hi everybody, this is my first post on diyaudio, although i'm following the threads for quite a while already.
I already built some amps (even successfully ), so i'm not a complete noob, but still there seem to be a lot of lessons i have to learn , which brings me to the problem i ran into recently...
one weekend, it came over me and i decided to build a veeeeeery simple, low power single ended class a amp just for fun. After I had put together the output stage, which i wanted to look at first, I switched on the power supply and was looking at a medium power rf transmitter...
For testing the thermal behaviour, the ops input was clamped to gnd and i expected to see ~-0.6V dc at the output, but what i saw on the scope was a ~15Mhz oscillation in the 2Vpp range. After i disconnected the top side of the circuit, i.e. the input section anc clamped the out node to gnd, i still saw the oscillation on the votlage over the low side shunt.
The current source seems to completely unstable, and the oscillation only stopped, after i bypassed the lowside shunt with a 22u electrolytic..
On the web, i found tons of circuits looking very similar but i didn't find any comments on instability of the current source. Actually, simulation showes only
a phase margin of 20° or so, that's why i wonder, if anybody stumbled across a
similar problem or is there some kind of "good design practice" or standard
compensation?
Any help and comments would be greatly appreciated !
regards,
defstone
Last edited by defstone; 17th June 2011 at 11:01 AM. Reason: schematic didn't show up
Old 17th June 2011, 12:49 PM   #2
Try to put 2k resistor into the base of Q7
Next step, put 100...1000pF film cap between the base and collector of Q7
Old 17th June 2011, 02:02 PM   #3
Thanx VladimirK,
I'll try that ! Your suggestion would imply that there's too much open loop
ac gain in the current source, right? That's what i assume, too...
just to show how unstable the circuit without compensation is, i did a
quick sim in ltspice. different devices, of course, but the effect is the
same as on my workbench.. power ramps up and the output, i.e. the
current source, starts to oscillate...
I'll post the sim. results with Vladimirs compensation when i have it
thanx,
defstone
Switching current source for Class A? QED047 Solid State 101 27th November 2010 02:49 AM
Current Source <- how to optimize? EE Solid State 85 2nd May 2010 09:08 PM
Replacing the cathode resistor with a current source in SE ? 2wo Tubes / Valves 12 6th November 2009 01:31 AM
Has anyone built Zen V9 as a current source amp? jimmyd53 Pass Labs 1 4th January 2007 03:04 PM
Quick question - possible to build high-power current-source Class D amp? 454Casull Class D 2 24th November 2006 10:48 PM
Page generated in 0.08532 seconds (67.30% PHP - 32.70% MySQL) with 11 queries
