diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   Sanken 2sa1216 and 2sc2922 (http://www.diyaudio.com/forums/solid-state/191008-sanken-2sa1216-2sc2922.html)
el_mariachi 17th June 2011 05:08 AM
Where can i buy matched set's of theese and be shure to get the genuine stuff and not the fakes?
To start with i need eight pairs.
I also need the capton insulation to mount them.
Best regards
el_m
lineup 17th June 2011 08:33 AM
2SC2922 2SA1216 Original Sanken Transistors - Buy Online @ AmpsLab
east electronics 17th June 2011 10:27 AM
you may also try your local YAMAHA service center
they sell them as spares in matched sets and are absofuckinlutelly originall ...expect them to be pricy
DreadPirate 17th June 2011 12:19 PM
B&D Enterprises - Electronic Components Distributor
el_mariachi 17th June 2011 01:47 PM
Thanks, but i dont manage to find any matched set's in theese webshops.
chlorofille 17th June 2011 01:49 PM
See post 2. You need to email Michael about matching. I've got a lot of transistors matched by him without any problems at all.
michaelchua(at)ampslab.com
el_mariachi 17th June 2011 04:10 PM
HelloSorry, I can't match the Sankens. Tried before
with my Tektronix 575. Beta too high. Not getting enough curves for accurate
readings.RegardsMike
homemodder 18th June 2011 10:30 AM
Here, Profusion plc, Audio Semiconductors and Components ,closer to home and very good price.
jorre2002 18th June 2011 12:54 PM
Sanken outputs
Hello there;
Just fyi in case you are stuck.
I have 2SA1494 and 2SC3858 's here coming from JBL power amplifiers.
All original and numbering matches.
Maybe they would do as replacement transistors.
I could ship you a few to fix 1 channel and check performance.
Remember:i don't do it for the money,only to help.
Grtngs;
jorre@skynet.be
RM 18th June 2011 08:20 PM
I have lots of these. However, I do not understand the need for matched ones. Surely you are using emitter resistors?
Roar
Resources saved on this page: MySQL 18.75%
