Sanken 2sa1216 and 2sc2922
Old 19th June 2011, 01:43 PM   #11
el_mariachi is offline el_mariachi  Norway
Originally Posted by RM View Post
I have lots of these. However, I do not understand the need for matched ones. Surely you are using emitter resistors?
Roar
Hi
Sent you a email.
el_m
Old 19th June 2011, 02:15 PM   #12
R.I.P.
One pair output stage using complementaries can benefit from hFE matching. This equalises the currents drawn by the bases and supplied by the drivers.
A two pair (or more) needs all the N type matched for Vbe (Vgs) and all the P type matched as well. Matching Vbe between N type and P type is almost impossible in multi-output pairs. Matching for hFE may be possible for multi-output pairs but is less important than Vbe/Vgs.
regards Andrew T.
Old 20th July 2011, 02:42 AM   #13
Francomusique is offline Francomusique  France
Roar
Hello,
I am also looking for such transistors, to repair one fried channel on my LC Ausio ZAPsolute Mk4.1.
I was wondering if I need to match them (there emitter resistors 3 x .27 Ohm in //)
And also looking for a reliable supplier for genuine parts in Western Europe (I leave in Paris).
Thank you for your help.
Old 20th July 2011, 08:58 AM   #14
R.I.P.
Is the output stage 1pair using paralleled emitter resistors?
or
Is the output stage 3pair using single emitter resistors for each output device?
regards Andrew T.
Old 21st July 2011, 01:29 AM   #15
Default Sanken 2SA1216/2SC2922
There is only one pair per chanel, with 3 paralleled emitter resistors.
I have attached some pics, showing the faulty area : R234 is burnt.
Old 21st July 2011, 09:29 AM   #16
R.I.P.
You do not need to match.
But, you will need to check output bias current and adjust as necessary.
This may change the output offset and need adjustment as well.
regards Andrew T.
Sanken 2sa1216 and 2sc2922Hide this!Advertise here!
Sanken 2SA1216 2SC2922, Genuine and Fake pictures Sunmansli Parts 49 15th May 2018 04:41 PM
2sa1216/2sc2922 metal Parts 2 21st February 2011 12:16 AM
Sanken 2SA1216 and 2SC2922 (again) len_scanlan Swap Meet 0 29th March 2007 08:34 PM
Sanken 2SC2922 & 2SA1216 quasi Swap Meet 2 27th March 2007 10:26 AM
FS: Sanken 2SA1216, 2SC2922 power transistors len_scanlan Swap Meet 1 13th January 2006 04:41 PM
