Yet another amp - simple inverted with 10x gain, mosfet output stage
Old 29th March 2012, 04:38 PM   #71
mikelm is offline mikelm  England
Send a message via Yahoo to mikelm
Well, I guess would only ever be a Power I2V converter but I didn't get around to it yet.
I have two amps a loudspeaker to build first.
Have to say purely as a symmetrical amp the SSA captured my imagination.
But ur design did seem most happy when fed with current.
I'll let you know . . .
Old 29th March 2012, 05:07 PM   #72
sonnya is offline sonnya  Denmark
sonnya's Avatar
I am not going to say anything bad on the SSA.
But i helped one building it (His own design) and i used ~40 hours on it. Before getting it stable.
I am not a fan of it, but it is new thinking and that i like a lot!
Old 29th March 2012, 05:17 PM   #73
yeah - I'm bumped into that also and didn't fix it yet - that design does "sail close to the wind" but I have the feeling that it will be worth it in the end.
It was the same with my DC linked version of Fetzilla but it came out very nice once I figured it out.
Old 29th March 2012, 05:54 PM   #74
sonnya's Avatar
This is going to turn.
We did get it safe, and the sound from it is true "current feedback" profile.
But you are right: the feedback makes it unsuitable for I2V powerbuffer.
I know that Andrej has it running with only +/-20mV drift. I dont knowwhat he did to make that stable, other thenm adding a cascode stage so that the VAS BJT's was less subjected to delta temperature and therefore a more stable vbe drop which again leeds to a more stable idle current.
Secondly he has degraded the VAS stage with 100K||100K.
I would really like to see some "real life" thd figures from it. But i suspect that with this VAS stage degeneration of ~50K it will be quite high.
Third: his gain is down to 16x where we used 21x
Fourth: his idle current is lower in every stage. Therefore less temp. changes in the BJT's
Without the VAS cascode and VAS degeneration we was down a drift of +/-50mV after adding a current source to the inputstage instead of emitters resistors (He fixed this problem more or less with an 1.5K NTC)
After adding a servo the drift is down to +/-1mV.
For the last version of my circuit (the last one in this thread) i got really low THD above CLASS A level, by adding a buffer stage before the mosfets. And it is 1/5 of the idle current in the mosfets.
This will be send to production next week.
So end next week i will have the PCB's up and running.
What i hope for this design is that i get really low THD of 0.006% just before clipping . But measurements will tell there story of it.
Old 29th March 2012, 08:47 PM   #75
sonnya's Avatar
Updated schematic with buffer.
Per sim it is stable into 8R||10uF.
The bandwidth is hitting 2MHz.
But to be that fast, a perfect layout is very important.
Old 30th March 2012, 08:08 AM   #76
Thx for the update - I will make ur changes in spice and check it out
Old 30th March 2012, 09:15 AM   #77
padamiecki is offline padamiecki  Poland
Originally Posted by kenpeter View Post
Like soOOOo. Or not?
It was interesting what Kenpeter proposed, I tried this and here are the results. Not bad at all... at 180mA idle works well too...
regards, Pawel
Old 30th March 2012, 12:26 PM   #78
sonnya's Avatar
See the difference to my version. There is 30dB less on second and third harmonic.
File Type: pdf simpleamp v11 noninverted FFT 1K 8W 8R take 290312.pdf (175.0 KB, 130 views)
Old 30th March 2012, 12:31 PM   #79
hm, you have hf switching hiss. it is -180db down @10MHz
in Kenpeter's proposition there is no HF hiss from >10KHz
but anyway I like you project very much
regards, Pawel
Old 30th March 2012, 01:30 PM   #80
sonnya's Avatar
My design switches more aprubt than with bipolar.
My gain is 10x higher also
Yet another amp - simple inverted with 10x gain, mosfet output stageHide this!Advertise here!
Simple stereo gain stage ss007 Analog Line Level 156 23rd August 2013 03:52 PM
Wanted: Zero feedback 2-10x gain line stage...prefer symmetrical Ric Schultz Analog Line Level 14 26th February 2011 07:26 PM
Voltage gain stage for Non-NFB MOSFET current amp gripracer Solid State 50 23rd October 2009 02:37 AM
AMP with inverting output stage mosfet fab Solid State 112 28th January 2007 04:32 AM
Elektor op-amp front-end with mosfet CF output stage Dusk Elektor 1 5th April 2006 04:09 AM
Copyright ©1999-2017 diyAudio
