Yet another amp - simple inverted with 10x gain, mosfet output stage
Old 14th April 2012, 09:21 PM   #91
sonnya is offline sonnya  Denmark
sonnya's Avatar
You have to draw this output stage. I cannot remember i have seen it.
The reason for the low distortion is the use of a driver stage for the mosfets.
You need to get rid of the gate charge and build it up fast. That requires a lot of current which the VAS stage cannot deliver.
I also discovered that standard current mirrors and folded cascode generates slewing related distortion. They both has to supply the compensation cap. And the output stage or the driver stage. The solution was to ADD current gain to the mirrors.
On the same time we need to raise the linearity of the mirror. That is the reason i have choosen Wilson current mirror.
The next problem was the fact that the current mirror with gain reducere the influence of the compensation cap by the gain factor.. We dont need more bandwitdh, just reducing the slewing distortion. So by applying the compensation cap across the current mirror fixed this problem.
I hope it explains how i Got there.
Old 14th April 2012, 10:04 PM   #92
mikelm is offline mikelm  England
Send a message via Yahoo to mikelm
My o/p darlington pairs are shown in this thread here:
http://www.diyaudio.com/forums/solid...ml#post2775430
Only I use zvn & zvp3310a instead of 4424a
Better than VAS driving lateral mosfets direct - now VAS sees very small i/p capacitance of 3310a . . . .
Perhaps 10mA still too little current to drive laterals ?
but much lower op impedance than VAS
Old 22nd April 2012, 06:31 AM   #93
hahfran is offline hahfran  Germany
Originally Posted by WuYit View Post
Without increasing costs...
"laws of semiconductor physics" forever forbid complimentary jFETs.
Forget such designs.
Forget complementary Wilson current mirrors. Yo cannot get that working in practice.
Old 22nd April 2012, 06:58 AM   #94
This inverting needs no compensation and is insensitive to "lack of complimentarity".
However a second PS is inevitable. D1 and D4 resp are thermal track diodes. Capacitors not shown here.
Old 22nd April 2012, 07:02 AM   #95
Not Q1 throu Q6 sit on a thermally conductive plate held at constant temp. That is n-times better than "thermal compensation". Those who understand semiconductor physics understand immediately why this must be so.
Further Q7 Q10 must be mounted on a heatsink separate from the heatsink Q8 Q9.
Old 22nd April 2012, 07:24 AM   #96
Power supply double star grounding
Old 22nd April 2012, 07:42 AM   #97
sonnya's Avatar
I do not fully follow you.
I think i have never spoken about complimentary JFET'S !? You can make a buffer with two N or P channel Jfets that will act like a complementary, but i don't think that this is what you mean.
For the record: Wilson current mirrors does work in practice.
Old 22nd April 2012, 08:16 AM   #98
But not complementary Wilson mirrors. of course one could select from a big bunch of devices those which yield a DYNAMICALLY (!!) complemnetry pair of Wilson mirrors but why? It is far more clever to follow a design rule that yields topologies insensitive to
such inevitable differences . Only ring-emitter or multi-emitter BJTs can be made dynamically complements, not simple Epi-planars. its not possible.
Old 22nd April 2012, 09:21 AM   #99
Hi Hafran,
You have not yet realised the full potential of having two separate secondaries & bridges in your PSU diagram.
Whether you use cheap noisy diodes of nice schhotky ones . . . when those diodes turn off a resonance will be excited in the secondary windings of the transformer - usually in the 1meg hz region.
In your diagram you are injecting that resonance directly into the amps earth - sonic disaster !
You need to either damp that resonance with a snubber cct or filter the earth lines before you make your star earth point - or do both !
Old 22nd April 2012, 09:32 AM   #100
PMA is offline PMA  Europe
PMA's Avatar
Even a foil cap of some 47nF across secondary may be a total cure. BUT - in any case - it is necessary to MEASURE the effect, there is no general rule, as parasitic impedances of the transformer and switching properties of the diodes used count.
Yet another amp - simple inverted with 10x gain, mosfet output stageHide this!Advertise here!
Simple stereo gain stage ss007 Analog Line Level 156 23rd August 2013 03:52 PM
Wanted: Zero feedback 2-10x gain line stage...prefer symmetrical Ric Schultz Analog Line Level 14 26th February 2011 07:26 PM
Voltage gain stage for Non-NFB MOSFET current amp gripracer Solid State 50 23rd October 2009 02:37 AM
AMP with inverting output stage mosfet fab Solid State 112 28th January 2007 04:32 AM
Elektor op-amp front-end with mosfet CF output stage Dusk Elektor 1 5th April 2006 04:09 AM
