balanced output
balanced output
Old 15th January 2002, 02:00 AM   #11
AudioFreak is offline AudioFreak  Australia
Warp Engineer
On Holiday
AudioFreak's Avatar
balanced output
wuffwaff.... you'd be best to use the circuit that sonnya has posted as it will be the most reliable and cause the least number of problems. It will also meet your criteria of 2 opamps in each signal path.
Old 15th January 2002, 03:10 PM   #12
blu_line is offline blu_line
blu_line's Avatar
Default balanced output
Why don't you use an instrumentation amplifier, like AD makes !
grtz
ST
Old 15th January 2002, 09:10 PM   #13
wuffwaff is offline wuffwaff  Netherlands
wuffwaff's Avatar
wich AD or BB instrumentation amps are you refering to?
william
Old 15th January 2002, 11:02 PM   #14
sonnya is offline sonnya  Denmark
sonnya's Avatar
Hi William
May i suggest DRV134/DRV135 from BB/TI (same company!) They are enhanced dropin replacement for SSM2142 from AD.
DRV134 and DRV135 are identical devices in different housing. DRV135 is in a SO8 house where it can't dissipate as much heat as the DRV134 ... Long cables or a load smaller than 600Ohm => DRV134
Sonny
Old 16th January 2002, 06:54 AM   #15
blu_line's Avatar
Hi William,
Types i do not know. I think i stick with the types Sonny suggested.
Most important is that the opamps inside are matched due to the fact that they are made on 1 piece of silicon. Perfect temperature and etc.... matching.
grtz
Simon
balanced outputHide this!Advertise here!
RIAA with balanced output? roger-k Chip Amps 4 1st May 2010 11:27 PM
Suggestions for balanced DAC output? ezkcdude Digital Source 11 18th May 2006 02:51 AM
D1 I/V, balanced dac, unbalanced output 00940 Pass Labs 2 30th April 2005 12:12 AM
ono balanced output pamaz Pass Labs 6 3rd March 2004 11:20 PM
