Old 14th June 2011, 09:51 AM   #1
Arroyo is offline Arroyo  United States
Default How can one tell if it is a lateral MOSFET
Hi I am looking for a 2sk405 and have a cross for an NTE 2393 just wanted
to make sure that the cross is a lateral mosfet as the original. Is there any
way of telling from the NTE spec sheet?
Old 14th June 2011, 10:27 AM   #2
Jay is offline Jay  Indonesia
Laterals have low Vgs threshold and usually lower capacitance (Ci). NTE2393 has Vgs threshold of 2-4v and Ci=1600pF. No it is not lateral. The low capacitance is the preferred characteristics.
Old 14th June 2011, 11:34 AM   #3
I am almost sure, the original 2SK405 is a good quality (has low Ciss) vertical MOSFET, not lateral, since one of the very specific features of laterals - negative Id temperature coefficient, starting from 100mA, is not the case here. It shows positive tempcoeff up to 4A, that is typical for verticals.
Old 14th June 2011, 11:56 AM   #4
CBS240 is offline CBS240  United States
CBS240's Avatar
Look at the transfer characteristics in the datasheet and note at what Id the zero temperature coefficient is, that being the point where the slope of the temperature graphs of Vgs vs Id are the same. Laterals are usually around 100mA while vertical types are a few to several amps. In the case of 2SK405 that point is about 3-4 amps.
All the trouble I've ever been in started out as fun......
Old 18th June 2011, 11:09 AM   #5
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by CBS240 View Post
Laterals are usually around 100mA while vertical types are a FEW to several amps.
For J115 it's way below 1A. (makes them an odd couple)
Looks like Sponge Bob has killed another thread.
BUZ901DP lateral mosfet wanted gaborbela Swap Meet 1 8th August 2009 11:50 AM
Lateral MOSFET thermal vs others jackinnj Solid State 6 21st March 2009 01:20 PM
emulating a lateral mosfet hitsware Solid State 3 11th January 2009 02:53 PM
Lateral MOSFET torture... megajocke Solid State 11 11th November 2007 07:08 AM
Lateral Structure Mosfet UltimateX86 Solid State 9 16th July 2004 09:50 AM
Page generated in 0.08064 seconds (75.77% PHP - 24.23% MySQL) with 10 queries
