Old 13th June 2011, 11:38 PM   #1
Default Correct bias setting for mosfet amp w/out scope?
I'm trying to verify the "correct" bias setting for a BK ST-140. It's the first model (Iron core tranny, (+/-) 49V rails, single pair mosfet outputs/Ch).
I read (on another forum) it is 200mA (or 100mA / output). However, I also read (in a stereophile review) that the first St-140 used 160mA bias and that the second model used less (140mA) due to a significant increase in rail Voltage (+/- 60V) when they were comparing the different ST-140 models.
I tried contacting BK but then remembered that they (shut down) not too long ago. Does ANYONE happen to know the CORRECT bias setting?
PS: I don't own a scope; (so I can't apply a sine wave and increase bias until crossover distortion disappears)!
Much appreciated!
Old 14th June 2011, 06:22 AM   #2
lineup is offline lineup  Sweden
lineup's Avatar
For MOSFET
100-200mA per transistor
lineup
Old 14th June 2011, 07:25 AM   #3
Banned
Do you have any more info about the amp ? Is it Class A A/B ? How many devices are in the output stage ?
Crossover distortion is normally pretty horrible to the ears.
If its Class A/B use the least amount of bias that produces a distortion free output.
If its Class A you need sufficient bias to ensure that the devices are conducting all the time.
Try to keep the output devices cooler than 65 Degrees for reliability.
Old 15th June 2011, 11:41 PM   #4
Yeah, I included all of that info in my initial post.... (SINGLE PAIR Outputs/ch). So, for 2 ch (stereo) that would be 2pair or 4 total!
I'm pretty sure it's A/B. It's definitely not A! Tranny & heatsink is too small!
I started the bias @ 150ma, didn't like the sound, so bumped it up to 200mA. To me, it still sounds somewhat "distorted" or veiled, but then again I've yet to "hear" a MOSFET amp that I thought sounded crisp/clean.
It's not running HOT but I don't wanna ramp up the bias too much and stress the outputs (there are on 2 (1pair) per ch).
Originally Posted by lineup View Post
For MOSFET
Again.... This was included in my initial post! One of the recommendations was 200mA (or 100/output). However, the difference in (say 200ma from 100mA) is essentially double the current. That's a pretty broad range.
I was hoping someone here either owned or serviced/repaired this amp at some time (BK ST-140) and happened to know the correct bias.
Thanks;
B
Old 16th June 2011, 12:43 AM   #5
bichi is offline bichi  United States
bichi's Avatar
a bit of additional BK ST-140 bias setting stuff:
Trouble with the bias B&K ST140
Old 16th June 2011, 10:35 AM   #6
the schematic in the post5 link has an error.
It shows complementary output stage but the lower device is upside down.
regards Andrew T.
Old 16th June 2011, 07:29 PM   #7
amptech is offline amptech  Scotland
Send a message via MSN to amptech
I would set bias for 100ma for a signal pair of power fet's...and see have you get on.
Nakamichi PA-7 & PA-5 Bias Setting? sourceoneaudio Solid State 6 8th March 2012 12:37 PM
setting bias mosfet amp Arroyo Solid State 3 23rd June 2011 12:18 PM
setting bias mosfet amp Arroyo Solid State 0 12th June 2011 09:38 PM
Threshold Stasis 2 Class A Power Amp - bias setting? speakerfritz Solid State 19 12th February 2011 03:28 AM
Setting Bias kptseng Solid State 9 8th March 2008 01:56 AM
Page generated in 0.10202 seconds (77.90% PHP - 22.10% MySQL) with 10 queries
