Working with a Conrad Johnson SA120 and having to replace outputs on one
channel. Have a circuit prior the drivers that consists of a single transistor that is positioned between the drivers ( bipolar driving a pair of mosfet drivers) collector driving gate of one driver emitter gate on other driver. Question I have is that there is a pot on the base collector of this circuit of this bipolar which I am aware should be the bias set. Is there any standard practice for setting this pot ? I assume one is trying to set the appropriate turn on range for the driver and output circuits ( 2sk405's, 2sj 115's). Any help would be greatly appreciated Thanks |
#2 |
ask the manufacturer for the service information that should state the bias setting and the method of applying and where to take the measurements.
regards Andrew T. |
#3 |
A general way to do it is when amp is warm:
1/ put your meter across output resistor and put meter on volts setting. 2/ turn bias pot until min volts on meter. 3/ Apply a sine wave to input and monitor output on scope. 4/ Turn bias up slowly until crossover distortion disappears.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#4 |
@ nigelwright7557 , do you recommend a certain amplitude of the output signal?
I think the sine wave should be ~1V peak to peak at output, and the scope set accordingly, this way the crossover distortion would be more obvious. |
| Nakamichi PA-7 & PA-5 Bias Setting? | sourceoneaudio | Solid State | 6 | 8th March 2012 12:37 PM |
| setting bias mosfet amp | Arroyo | Solid State | 0 | 12th June 2011 09:38 PM |
| Threshold Stasis 2 Class A Power Amp - bias setting? | speakerfritz | Solid State | 19 | 12th February 2011 03:28 AM |
| Setting Bias | kptseng | Solid State | 9 | 8th March 2008 01:56 AM |
| bias setting | ben goh | Solid State | 8 | 14th August 2006 04:26 PM |
| Page generated in 0.09506 seconds (74.44% PHP - 25.56% MySQL) with 10 queries |
