i have a pioneer A400 which has developed a problem when you switch amp off sometimes the speakers pop as though the relay is slow and not switching the speakers off before the amp powers down, it takes about 5 seconds for the relay to kick in from switching on the amp . i have measured the voltage at speaker posts with no speakers connected and at switch on reads 50mv dropping to 3 to 5 mv on each channel ? .
#2 |
there might be something wrong with the sequence of shuting down the relay quickly
on the other hand it could be as well a capacitor issue .. To be more specific since i cannot analyze the protection circuit for you , any capacitor that is leacky might provide less or improper voltage resulting that amplifier goes out of balance during shut down . ( in such a design that stays in balance till complete shut down the protectin sequence is not that importand ) one could look at the protection circuit but also a good inspection on the capacitors especially in the protection psu and auxiliary psu schematic is available if you like to have it just e mail me kind regards sakis
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#3 |
hi thanks for the advise sakis i have found it was the bias set too high, it was set at 60mv per channel.
60mv divided by the resistor 0.33k = 181ma . i have set it to 20 mv and the problem has gone . will try to get it up to about 50mv which is 151ma as the higer bias current gives a better sound stage . |
#4 |
i am not really sure that you are in the correct track ....
| pioneer A400 | glennjarrett | Solid State | 2 | 13th June 2011 07:35 AM |
| pioneer a400 | reddish75 | Solid State | 24 | 21st September 2008 11:14 PM |
| pioneer a400 schematic | reddish75 | Solid State | 2 | 19th September 2008 11:31 PM |
| bias for pioneer a400? | lt cdr data | Solid State | 7 | 18th November 2006 10:02 PM |
| Buzz on Pioneer A400 | Smiffy | Solid State | 4 | 16th January 2006 05:38 PM |
| Page generated in 0.08124 seconds (72.27% PHP - 27.73% MySQL) with 10 queries |
