Old 9th June 2011, 10:17 AM   #1
Default nad 3020 volume control
This maybe a seem like a stupid question but can i put a 20k alps rk27 in there in place of the original only asking as the original is a kb pot and the alps is a ka.
thanks
Old 9th June 2011, 12:15 PM   #2
thanks
The original pot has a linear track whereas the Alps is an audio taper or logarithmic track. The only difference you will notice is that you will have to turn it up to a higher setting than you currently do and the new pot might be a bit 'endy'. The other thing is that you will not be able to connect the 40% tap on the existing pot which is used for the loudness control, hence it will no longer function.
Why do you want to change it the Alps pot is not going to improve the sound quality, is the old pot knackered ?
Old 9th June 2011, 12:54 PM   #3
yep the old pots had it, what do you mean a bit 'endy'
Old 9th June 2011, 01:07 PM   #4
The volume increases dramatically at one end of the pot without much rotation.
Another NAD 3020 jerryo Solid State 17 3rd May 2012 06:39 PM
Did i ****** my NAD volume control? GhettoSQ Solid State 12 11th November 2007 05:42 PM
Removing NAD T753 Volume Control Knob sonicrealism Solid State 6 10th September 2007 07:35 PM
NAD 3130 left channel dropping in and out as I turn the volume control was8v Solid State 2 1st July 2007 06:16 PM
NAD 3020 amplifier volume problems Neilb Solid State 7 20th December 2006 11:44 PM
Page generated in 0.08043 seconds (69.93% PHP - 30.07% MySQL) with 10 queries
