Old 8th June 2011, 01:02 PM   #1
Thoru is offline Thoru  Netherlands
Default Large signal distortion in pre/VA stage
I've designed a new amplifier based on a Slone amplifier (3 stage topology).
My goal was to use lower noise and SMD components.
Schematic is at here at page 2.
At the moment I've only build the input and VA stage, so everything to the right of the line R4-R47 is not installed on my PCB (except power supply components of course).
When I measure the amp with an Audio Precision, I get an increase in distortion from 300mV in, while it should readily accept 1V. (see attached plot).
How can I find the source of this distortion? Do need to switch some transistors for a different type?
Thanks in advance.
Kind regards,
Remco Poelstra
Old 8th June 2011, 01:36 PM   #2
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Thanks in advance.
Kind regards,
Remco Poelstra
Remco,
It seems that your amp clips at 800mV in. If you know your max Vout and divide by the gain you should get at 800mV. Also, this is most probably VRMS so 800mV is really 1.12V peak.
Does that help?
Edit: I saw your gain is about 30 and your supply about 33V so the max Vin is expected to be about 1.1V peak, which fits.
Of course the distortion will go up a bit before that, and you see that in the graph.
BTW I will visit Duran this Friday with the AES; will you be there? We can take a look if you want.
jan didden
/Another new issue: Linear Audio Volume 3!
Old 8th June 2011, 01:41 PM   #3
Yes, it clips at about 800mV at the moment. I'm concerned about the rise in distortion between 300mV and 800mV. I had expected a more sharp changeover from decaying to rising distortion at clip level.
Old 8th June 2011, 01:50 PM   #4
and yes, I'm at the AES meeting
Old 8th June 2011, 02:09 PM   #5
I try to get a 20dB overhead between clipping and normal maximum output voltage.
If you clip at ~30V then normal maximum of 3V is @ -20dB.
Most CDP are ~2Vac and ~3Vpk at maximum signal. Even an overhead of 12dB will keep your normal maximum signal well clear of the distortion rise when output exceeds ~15V.
But this overhead is applied to source and line level gain stages.
In a Power Amp, we don't have that luxury of overhead above normal maximum. We rely on feedback to reduce stage distortion as the power amp approaches clipping.
regards Andrew T.
Old 8th June 2011, 02:17 PM   #6
janneman's Avatar
I think your graph shows a typical behaviour for the type of circuit.
Let's talk Friday!
jan didden
Old 8th June 2011, 02:18 PM   #7
I do not fully understand your posting about the overhead.
But does the overhead matter in this case? Whatever the optimum input signal is, I think it's strange, or at least unwanted, that it starts to distort disproportional before clipping.
Some transistor must have a hard time in that circuit and I wonder which one and why .
Old 8th June 2011, 02:21 PM   #8
The standard technique to begin to look for a cause is to change the frequency. Try a much lower frequency it will show if it is a gain vs frequency or gain vs voltage level issue.
Old 10th June 2011, 01:07 PM   #9
Made some extra measurements and it's independent to frequency.
Maybe it's the input stage that has to make a larger swing and it has problems with that?
Old 10th June 2011, 01:12 PM   #10
Then I think you had it right from post #1, try switching some transistors to see what moves! I am so used to seeing the type of curves you showed when looking at audio power amplifiers, that I never bothered to determine if it is one stage or two stages of distortion or even an artifact of the transistors construction.
two-stage soft-start for large toroidals panson_hk Power Supplies 10 19th August 2010 12:02 PM
new technique to measure audible distortion and signal degradation Kulish Mikhail Software Tools 8 13th April 2010 09:10 PM
Low Distortion Signal Generator EchoWars Everything Else 150 6th March 2010 02:56 PM
Transformer VA versus output power VA nigelwright7557 Solid State 8 18th May 2008 02:57 PM
what about Large signal parameters crissty Multi-Way 5 15th May 2005 06:44 AM
Page generated in 0.12533 seconds (62.48% PHP - 37.52% MySQL) with 11 queries
