Old 8th June 2011, 09:54 AM   #1
Arroyo is offline Arroyo  United States
Default Determing current dump from output transistors
I have acquired a new amplifier and with no reviews all I have to go on for
potential current output is Ic from the output devices. From my figuring
the maximum current potential is the sum of each rails output device rating.
Ex: Ic 10a per device, two devices per rail ( IE pnp, npn ) thus equaling
max current dump of 20 A. Am I figuring correctly?
Thanks in advance
Old 8th June 2011, 11:18 AM   #2
No,
you have to look at the SOA plot for the device and also take account of the device temperature when this peak current may be demanded.
ESP gives a circuit and method to nondestructively test this peak output current, at normal operating temperature.
regards Andrew T.
Old 8th June 2011, 11:34 AM   #3
ampmade is offline ampmade  Belgium
Do you want to know the exact available power of your amplifier?
Old 10th June 2011, 01:19 AM   #4
Default Trying to obtain available current capacity
Just as I has stated have the rating of the output devices and know the power
supply is more than adequate for these ( actually far in excess). I am thinking
of either using this amplifier with a pair of Apogees that are quite current hungry or finding another amp. Not interested in wasting time trying to
use an amp which will be useless to my cause. My Cal sigs should draw
close to 35 A at full load from my figures..
Would it be nice to have constant current on the output transistors ? Bernhard Solid State 11 12th April 2009 12:31 PM
My dump is better than your tip jackinnj Everything Else 6 9th April 2009 08:49 PM
Determing Battery Voltage for cathode bias jeffdavison Tubes / Valves 8 13th August 2008 04:26 PM
determing speaker power philspeed Multi-Way 0 30th April 2006 11:50 PM
Let's Play 'Dump the Cap' EchoWars Solid State 15 21st February 2003 12:04 PM
Page generated in 0.07723 seconds (72.92% PHP - 27.08% MySQL) with 10 queries
