Hello
I remember the very good sound of the first Denon PMA-700 amp from the 80's, in those time I never seen the schematic and can't find the first version schematic of that amp. But I have the PMA-700AE schematic, what is the differences between the PMA-700 amp from the 80's schematic and the recent PMA-700AE schematic ? Thank Bye Gaetan |
#2 |
This looks like the new one:
http://www.hifiengine.com/manuals/denon/pma-700ae.shtml Isn't this the old one: http://www.hifiengine.com/manuals/denon/pma-700v.shtml Last edited by DreadPirate; 7th June 2011 at 03:38 PM. |
#3 |
This amplifier use Denon s generic schematic that consist
of three serial connected differentials, the first one at the input using jfets. Performances of this design are better than both the usual single differential as in the blameless and the dual serial differentials as used in Hitachi or its numerous copy ala goldmund. As an exemple of that Denon s lineup, the POA3200. Last edited by wahab; 7th June 2011 at 07:43 PM. |
#4 | |
I've look at that pma-700v page, it is a quite recent version. Thank Bye Gaetan |
#5 |
The PMA-700V looks like the original with the dynamic bias circuit, the 700AE does not have this.
Candidates for the Darwin Award should not read this author. |
#6 |
Great amplifier, the 700V, very powerful but not invasive,
I loved it. Now the balance pot (220k) died, and its not easy to find a replacement. There are 2 service manuals floating around, one with incomplete schematics. PM me if you need it. |
#7 |
Banned
This was the first amplifier that I had that would show the difference between speaker cables. If you haven't tried them, try using 2.5mm ring main cable (26A for non UK).
#8 |
Hello
I remember that there was an article in the audio magazine La Revue du Son and wroted by Jean Hiraga in the early 80's , the Denon PMA-700 was tested with a spectrum analyser, the thd spectrum was mostly 2 nd and 3 rd harmonic with no high frequency thd harmonics, doing spectrum analyser tests was quite new in a audio magazine in the early 80's. In those years most transistors amps was not so good. I was just currious to see the first PMA-700 and see why this amp was so good. If I understand correctly, the PMA-700V are the same schematic than the first PMA-700 ? Thank Bye Gaetan Last edited by gaetan8888; 8th June 2011 at 10:39 PM. |
#9 |
The "V" probably signified "video", as the amp has the capability of 2 video line ins (stereo audio + composite video signal over rca) selectable via switch.
Here some infos on the 700V: DENON/COLUMBIA PMA-700V The older 700Z was released 10 about 10 years earlier. DENON/COLUMBIA PMA-700Z The (realtively) new 700AE is another build. What they all have in common, apart the "700" is still a mistery to me. |
#10 |
Hello
I've done a quick look at the PMA-700AE, the PMA-700Z and the PMA-700V schematics. The PMA-700Z are the one made arround 1979, today it would be a classic circuit but in the late 70 it was quite something. The PMA-700AE are much more recent and it have a more refine fet input front end in the power amp section and a better power supply. The PMA-700V are very different, there is no LTP in the front end in the power amp section but it use Ic's, and it also have a better power supply. I don't really like the use of Ic's in the front end of an amp. Bye Gaetan Last edited by gaetan8888; 9th June 2011 at 10:52 PM. |
| Denon PMA-750 Integrated Amp | wildmonkeysects | Swap Meet | 3 | 17th December 2009 11:15 PM |
| Denon PMA-520 Integrated Amp "Buzz" | DreadPirate | Solid State | 8 | 9th February 2007 08:39 PM |
| Denon PMA 2000RIV | Al Raj | Solid State | 32 | 27th January 2007 12:05 PM |
| Denon PMA-250 | edl | Solid State | 3 | 6th November 2006 11:59 AM |
| Denon PMA 770 - Schematic & PCB layout - Anyone got one? | GeorgeBoles | Solid State | 1 | 29th September 2004 11:50 PM |
| Page generated in 0.15780 seconds (53.73% PHP - 46.27% MySQL) with 11 queries |
