Hope this is in the right place. If not, could someone please move this to the appropriate place? Thnx...
Last night I wanted to kick back and enjoy some music. So I switched on my CD-player and preamp, waited for the pre to come on temperature (tubes...) and switched on my poweramp. Well... I tried to. The big powerswitch on the Threshold S/300 felt 'lame', like there was no mechanical resistance, and the red LED didn't light up. So I said some very bad words and unplugged the powercord. After checking the fuses on the back (they were all good) I plugged in the powercord again and tried the switch again. And it worked! It felt normal and the amp runed on. The Threshold sounded as good as ever, so I enjoyed the music untill bedtime. But now I 'm thinking.... should I be worried? Might this be a sign I'm in for trouble? The amp was revised some years ago. Some small caps were replaced (not the big power caps), bias adjusted and it had a thorough cleaning. According to the tech who did it he didn't find any trouble and he gave the amp a clean bill of health. So why didn't the amp worked when I turned it on the first time? And can I listen as usual or should I have the S/300 checked first? When it finally worked it sounded as good as ever driving my Apogees, so no complaints there. Any advice? |
#2 |
Start at the cheap option faulty switch.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#3 |
Thnx for the answer. Unfortunately, according to the manual, the on/off switch isn't a normal mechanical device, but "... a resetable circuit breaker which will also disconnect AC power to the amplifier if a potentially dangerous failure should occur."
| Threshold S/300 | rbwinterlink | Pass Labs | 2 | 11th October 2010 05:29 AM |
| threshold TA-300??? | Williams Audio | Pass Labs | 0 | 5th December 2007 07:48 PM |
| Threshold S/300 for Sale in Philly | vdi_nenna | Swap Meet | 5 | 17th June 2006 08:26 PM |
| Threshold Stasis S/300-2 optical a-ab | georgehifi | Solid State | 3 | 30th September 2003 02:18 PM |
| Threshold S/300 mods? | LNeilB2 | Solid State | 1 | 24th October 2001 01:08 AM |
| Page generated in 0.07281 seconds (78.37% PHP - 21.63% MySQL) with 10 queries |
