Old 6th June 2011, 03:06 PM   #1
Default Studio Project C1 preamp MOD
Hi guys,
I have an "entry level studio" condenser microphone SP-C1.
I want to mod or replace the preamp inside the capsule with the goal to have a lower noise floor. The preamp is made of 1 FET tranzistor and another 4 BJT.
All film caps are Polyester from WIMA or unbranded 10nF.
Soon i will post the schematic(i will try to copy it form the PCB traces) and some pics of the board and component values.
It looks well build but i want to make a better one.
current specs:
Noise: Line): 27dB (A weighted)---17dB
S/N: 77 dB
Does anyone have a diagram for a discrete or opamp hi-fi - premium condenser preamp/buffer?
It would use phantom power, i am also building a small mixer and i can implement custom "phantom power" special for this modded microphone.
I think i should have posted this topic the Analogue Source section.....
Old 6th June 2011, 03:19 PM   #2
lineup is offline lineup  Sweden
lineup's Avatar
What is the phantom supply?
How many volt?
lineup
Old 6th June 2011, 03:59 PM   #3
Send a message via AIM to Stormrider Send a message via MSN to Stormrider
Typical phantom power supplies are +48Vdc.
AJ
Old 6th June 2011, 06:51 PM   #4
Now it uses +48 Vdc, but if needed i could make it a split power supply of +15Vdc -15Vdc.
Also, from what i have learned is that the condenser capsule must be polarized with approximately 35V, usually this is done through a big resistor >1 G ohm.
Old 7th June 2011, 12:12 AM   #5
I managed to draw the diagram studying the PCB trace.
All resistors except R12 are 5%. Caps look real cheap. I would change them (except the resistors around the Q4 FET) I want a lower noise floor.
Wouldn't mined to also change the sound a little, a little to bright stock - look at the freq resp graph.
Any ideas?
Old 7th June 2011, 03:05 AM   #6
Previously: Kuei Yang Wang
ThorstenL's Avatar
First, the circuit is mostly straight out of Neumann Mike, not a bad place to start I would add.
Originally Posted by kategra84 View Post
I managed to draw the diagram studying the PCB trace. All resistors except R12 are 5%. Caps look real cheap. I would change them (except the resistors around the Q4 FET) I want a lower noise floor.
The noisefloor in Condensor Mikes is pretty much determined by the impedance (capacitance) of the Capsule, this is sufficiently large to cause significant noise. There are not many options to deal with that in circuit.
You could try different Fets, but I suspect the 2N5457 will already be within a few dB of the theoretical limit.
So one of the two optiosn is to get the mike closer so you get more SPL, the other would be to change the capsule for one with more level AND more capacitance (in both cases at least 3dB/1.414 times more).
You could try adding some EQ to create some HF rolloff in the Microphone, however I somehow doubt that this is really the problem, if a bit of EQ does it, you can always add this in post production.
It may be worthwhile poking a 'scope probe around the circuit to see if you get any breakthrough from the small chopper that creates the polarisation voltage for the Capsule, if so shielding/better filtering may be needed.
But it may be very well a limitation of the microphone capsule, so again, the only way to fix this may be to replace the capsule.
Ciao T
near field studio monitors based on KEF iQ7 mod singleend Multi-Way 3 16th March 2011 02:41 PM
Kenwood C1 preamp schematic anyone ?? Jan Dupont Solid State 0 18th June 2007 03:29 PM
Studio Tube Preamp morebass Tubes / Valves 13 11th March 2007 12:26 PM
studio amplifier project? rotation Solid State 3 2nd February 2006 09:18 PM
studio amplifier project? rotation Chip Amps 2 2nd February 2006 04:33 AM
Page generated in 0.11077 seconds (77.03% PHP - 22.97% MySQL) with 11 queries
