Old 6th June 2011, 09:54 AM   #1
Default LT1166 bias IC
Dear All,
Who can tell me more about this "auto bias" IC. I used the search function and read the different opinions. Also I Purchased the awesome book "Designing Audio Power Amplifiers" from Mr. Bob Cordell where he went deeper on this chip.
I fear I don't really understand this IC yet.
As far as I understand (and please correct me if I am wrong), The IC forms an integrator by sensing the voltage drop over the emitter resistors. The servo keeps the DC voltage at 20mV. by adjusting the VBE multiplier transistor inside the chip. Am I correct so far?
Then I wonder what does the chip when the musical signal exceeds the bias current. Will it slides with the music, or does the amplifier switch into class B?
I read about concerns of added distortion mostly in the HF frequencies, since the VBE multiplier modulate with the music signal. Bob Cordell provided solutions for this.
I was wondering, why not only use the servo/integrator part of the chip, and let the chip drive an LDR or an optocoupler in the bias string? A resistor and capacitor can slow down the fluctuation.
Maybe I am all off here, but I hope for some share of thoughts.
Thanks in advance.
With kind regards,
Bas
Old 3rd September 2011, 03:21 PM   #3
LTspice IV comes with a model of the LT1166 included. A simulation can provide at least some answers, if not all.
Linear Tech. LT1166 chip smoking-amp Solid State 13 7th September 2011 07:15 AM
Dynamic Bias - Active Bias - Automatic/Self biased - Overview wanted tiefbassuebertr Pass Labs 11 5th May 2011 08:42 PM
search pcb with IC tl494 or other Ic to build a smps caraudio Ground Zero Car Audio 0 13th December 2010 04:58 PM
Replacing Bias IC with Individual Transistors scsidude2 Solid State 5 23rd May 2010 06:28 PM
Stray hum pickup *preamp* cathode R-bias vs. battery bias & 12AU7vs.5687 awedio Tubes / Valves 2 19th April 2008 01:30 AM
Page generated in 0.09368 seconds (63.20% PHP - 36.80% MySQL) with 10 queries
