Just wondering how to design a source follower output stage. (Class A SE) with a resistor as the load and not a CCS?
I understand that it would be extremely inefficient. Looking for about 10W into 8ohms. Probably cap couple to load. 1.5A bias current or so. Thanks for any help or any links to how to work out the values i need.
It is not you... you are it. |
#2 |
What output transistors do you have or think of?
lineup |
#3 |
It takes a lot. For 10 Watt.
10 Watt is SQR(10*16) = 12.65 Volt peak Most effective would one 8 Ohm power resistor. Supply need to be more than 3x12.65V. Probably 42VDC. Current needs to be more than 3.16A Say 3.40A. Across power resistor would be ~27-28 Volt 27V x 3.40A = 91.8 Watt 8 Ohm resistor. You could use 4 resistors 8.2 Ohm Each should be rated more than 25 WAtt You can see in my simulation how one could do.
lineup |
#4 |
With constant current source
there will be slightly smaller heatsink. Trafo 2x22 VAC for rectified 30VDC
lineup |
#5 |
would it be easier to do as a BJT or a Mosfet?
I was thinking mosfet.. as an example a IRF240N or something. Like i said i dont care how inneficient it is.. just 10W 8 ohms and nice gradual clipping etc. Thanks!
#6 |
i did some sim and i came up with
45vdc supply. 8 ohm resistor for load. 3.75A bias using IRF240 can get about 14v peak into 8 ohm load at clipping. 12v peak into 4 ohm load at clipping. can u confirm this? ends up being like 35v bias for the 30v drop across the 8ohm resistor load. hope that makes sense. lol.
#7 |
Yes.
All the figures make sense. But it must a h**l of a power resistor. 30v x 3.75 = xxxx Watt !!!!! But if you have 4 power resistors rated 50 Watt each then you can use those four 8 Ohm resistors together. Difference by using MOSFET or BJT. Both can be used. But we get more dropout voltage with MOSFET 0.7Volt and 4v is a difference 3.3v in favour of BJT So teoretically MOSFET need at least 3.3v higher power supply.
lineup |
#8 |
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
| Source follower and common source output stages | slogan2112 | Pass Labs | 2 | 9th October 2008 08:19 PM |
| output impedance of source follower and load in mH? | AudioGeek | Solid State | 2 | 18th November 2005 11:02 PM |
| Aleph-type current source, but source follower this time | tschrama | Pass Labs | 4 | 29th July 2005 12:55 PM |
| Source follower electret mike -> use with current source? | capslock | Solid State | 1 | 28th February 2003 12:54 PM |
| Linearized Source Follower | mirlo | Solid State | 37 | 4th August 2002 08:49 PM |
| Page generated in 0.14574 seconds (59.10% PHP - 40.90% MySQL) with 11 queries |
