First off...Has anyone gotten the LM1972 working properly from a microcontroller? I am going to be using this in my project and would like to know if there is any pop when going from 100% to MUTE? I am going to use the suggested LF412ACN buffer on the output, but if anyone has any other suggestions that would be great.
Next thing is how do we take a XLR balanced and make it unbalanced. And then take that unbalanced signal and transform it back to balanced? Reason being, I want to take the XLR signal and attenuate it and it would be easier if it was unbalanced. |
#2 |
I'm running the LM1972 from a PIC16F84 (iirc) and have no problems with pops, except when doing sine wave tests. I haven't tested it from 100% to mute in one step, since it would be waay too loud. If it turns out to be a problem, you could always ramp the volume down to mute over a couple of steps, and the same when returning from mute.
I had to buffer the LM1972 inputs and lower the input voltage to avoid clipping (halved it), which is something to be aware of. It is possible I've made an error in implementing the LM1972, but I got the hint from some page online, so I am not the first to have that problem. The dpot outputs need to be buffered anyways, so you can easily regain the lost gain, though it might be suboptimal. |
| FS:ultimate attenuator kit for audio,balanced/single-end | bbp | Swap Meet | 11 | 21st July 2011 01:22 PM |
| XLR audio pad attenuator | frenchie29 | Instruments and Amps | 0 | 1st May 2009 09:44 PM |
| Balanced To Unbalanced Audio Converter | SprockeT1597 | Parts | 3 | 7th February 2009 04:03 AM |
| going from XLR to unbalanced, is this ok? | Jean | Solid State | 1 | 14th March 2003 07:23 PM |
| unbalanced/balanced/unbalanced conversion using transformers | vladimir | Solid State | 10 | 27th February 2003 06:54 PM |
| Page generated in 0.07681 seconds (67.96% PHP - 32.04% MySQL) with 10 queries |
