#41 |
Warp Engineer
On Holiday
PassFan,
The amp is Class B or AB so will not have much in the way of quiescent dissipation........ Also the supply is transformerless and each 900W amp will have a seperate power supply ..... |
#42 |
I think GRollins has made something like a watercooled amp.
#43 |
Actually, it will have one power supply for all 8 channels. It will have a 60A breaker as an on/off switch, 4 150A discrete rectifier diodes, at least 8 200V, 31,000uF filter caps (not much for a brute like this, I know, but it will have a high PSRR, and besides, those caps are huge and expensive), smaller electrolytics, film caps, two MOVs, 20W bleeder resistors (I'd hate to see those caps discharge into a screwdriver!! There wouldn't be a srewdriver left, I'd be seeing spots and have a ringing in my ears for a week!), and possibly two big inductors mounted in a compartment under the rest of the chassis.
I wonder how much tubing I'd need in the heat exchanger for this thing? |
#44 |
Warp Engineer
On Holiday
thats not gonna be anywhere big enough for this amp kilowatt.. on transients this amp is gonna load down like crazy if it doesnt have heaps and heaps of low resistance capacitance in the power supply and because all channels will peak @ the same time, the peak current draw will be in excess of 100A
#45 |
KiloWatt, I don't know if anyone else has asked this exactly, but what are you going to use this thing for?? Simulating earthquakes, producing 5 hz tones at 140 db? This is a serious amount of power. Of course you could just be doing it for fun which is a good enough answer for me. But if you really need that much power, wouldn't it be cheaper to buy a comercialaly made amplifier setup? I know that a crown ce2000 is rated at 975 watts/channel into 2 ohms and they only cost about 550. Get 4 of these and you have your power requirements, it will only cost 2200 dolars for all 8 channels, all of the protection circuitry is built in, all of the cooling is built in, and to top it all off, there is a warrenty and they only wieigh about 40lbs each.
Not that I want to put a damper on the DIY spirit. Sometimes it is cheaper and wiser to go comercial. It's like designing a robot that can clean dishes when there are 200 dollar dishwashers for sale in every department store. But if this is a just for fun project, then good luck and take plenty of pictures for us all to see. |
#46 |
Warp Engineer
On Holiday
the problem with the above mentioned amp is that it produces 975W into 2ohms.... Kilowatt needs that kinda power into a 12ohm load.
#47 |
Also, the 7200W amp by itself will not cost more than $1000 US to build, not including the outputs I'm likely to blow up, of course.
How much capacitance should the power supply for this have? |
#48 |
Where will you find a 12000 watt transformer for 1000.00?
#49 |
I won't, the power supply won't have a transformer. If you read this whole thread, you'd know that. AudioFreak said that just a few posts back.
#50 |
He's going to use the transformer up on the Utility pole.
I posted an explaination earlier in this thread. Phil |
| Mosfet Amplifier | Telnet100 | Solid State | 1 | 28th January 2009 02:56 PM |
| MOSFET amplifier | ash_dac | Solid State | 6 | 5th December 2006 09:55 AM |
| MOSFET/MOSFET amplifier | jarek | Pass Labs | 21 | 22nd June 2004 06:04 PM |
| Page generated in 0.09842 seconds (78.60% PHP - 21.40% MySQL) with 11 queries |
