Old 24th June 2002, 10:00 PM   #181
Warp Engineer
On Holiday
AudioFreak's Avatar
I concede that I am not highly familiar with horns so I suggest you listen to the guys that are but i'm still more than a little concerned about the amount of EQ you will have to use with car subs maybe the horn loading will fix it ... actually it should help alot but i'm still not totally sure whatever you do, a well designed horn will give quite a few dB lift in efficiency so you could use a few dB of EQ and still come out ahead. Good Luck! (I've got a 6 hour long engineering exam that starts @ 8:45am hehehe oh what fun!)
Old 24th June 2002, 11:21 PM   #182
Yeah, horn loading ought to help alot, even if I still need some EQ. Anyway, good luck on your exam, but I don't know when 8:45 a.m. is over there. It's 3:20 p.m. over here in Montana.
Old 25th June 2002, 12:18 PM   #183
Warp Engineer
On Holiday
AudioFreak's Avatar
FWIW, it was about 6am when i posted that message this morning...
Old 26th June 2002, 03:46 PM   #184
SteveG is offline SteveG  United States
Account Disabled
Here we go again making things much more difficult than they have to be. I give up.
Old 26th June 2002, 10:37 PM   #185
What? How am I making things difficult? What should I do?
Old 27th June 2002, 12:35 AM   #186
jleaman is offline jleaman  Canada
Send a message via AIM to jleaman Send a message via MSN to jleaman Send a message via Skype™ to jleaman
this post was a joke... 13 pages of crap...
Old 27th June 2002, 12:55 AM   #187
It was? News to me, I thought we were actually getting somewhere for a change (making it only 9 or so pages of crap). People were saying I was on the right track now, that I was coming to my senses, and that it might actually work. Was this not true? You make it sound like people were just leading me on, or vice versa. What are you taking about man? Even you seemed to be with me on this for a time!
We were just going along smoothely, talking about what I'm going to use for subs, there was no tension, and then all of a sudden........ "shut up, Kilowatt, you're wasting our time and making an *** of yourself" like for no reason, what's going on? Don't think I should even make the system at all? What the hell do I have to do to get a little help around here?
Old 27th June 2002, 04:54 AM   #188
mrfeedback's Avatar
Default Truth In Answering
Kilowatt, you need to define to us very clearly exactly what you are wanting to achieve, in what environment, who for, your experience and your gain through your involvement - Then we can prperly help you, but you need to be TOTALLY HONEST.
So far you have posted continally changing ideas and suggestions and so far no real results, except for wasting bandwidth and annoying your seniors.
So, spill the beans and we'll help, and no more outbursts from you thankyou.
Eric.
Old 27th June 2002, 05:57 AM   #189
I have to side with Kilowatt on this one.
Killowatt even said First of all, I listen to everyone here, age doesn't really matter, in fact, the older guys here are obviously more experienced and wiser. which makes the statement ... wasting bandwidth and annoying your seniors. just a bit mean.
When brainstorming, it's possible to wander around a bit, but I'll admit I'm not as clued into the history on this one.
Posted by JasonL:
humm then get 8 ohm subs then hehee and yeah i would get the ones for 33xmax because of out doors yuo wont hear it bottem out LOL also the sedrvo drive ones are going to be tricky though.. and for car subs they will work out doors no problem.. JasonL
Posted by JasonL
I just think that's funny. Poster, Edit thyself!
== John ==
Old 27th June 2002, 06:19 AM   #190
Thank you, jgwinner.
But to further justify my cause,
I thought you knew exactly what I want to do. I'm glad someone finally explained the deal, all I've been getting is "outbursts" from others. People saying "Screw you" instead of a more appropriate "Just what are you trying to do here?" That doesn't seem quite right, so please don't accuse me of being harmful to this forum's friendly air.
Anyway, what I want to do is build 14x450W into 2 or 3 ohm amps (depending on what speakers I use) and 16x56.25W into 8 ohm amps. 8 for woofers, 6 for mids, and the 16 56Wers for treb. That's the plan anyway. That totals 7200W. This figure is based only on the fact that I couldn't get much more class AB power from a 12kW outlet. All of them would be CF MOSFET amps, and preferrably in the same chassis because I already have a water cooling system that would be perfect for all the amps together. They would have to use switching supplies, unfortunately, because 60Hz power transformers for it would weigh over 200lbs. The making of the amp isn't so much the issue because I can deffinately do it. There are plenty of plans for 450W amps out there, and I know enough to design my own by now. The issue is the speaker system. I want to use the amp outside, there are no amphitheare type things around here, only flat landscape and forrested mountains. It is not so much a PA system designed specifically for putting on shows for large audiences, though there is certainly plenty of power for that. It's more of a large stereo, and I want it to have as close to hifi quality as possible. Quite a challenge outdoors. The reasoning behind it is somewhat similar to the reasoning behind those 160dB car systems, only the sound quality is ever so much better, and the system is ever so much more marketable, or at least useful if I ever need a PA or something really powerful. If nothing else, I could take it apart and sell the individual amps and PSUs if I want to get rid of it and can't sell it. It should cost only as much as many PA systems with lower power and fidelity, perhaps as little as $10,000. There are people that would spend that much on a 2x60W tube system with passive crossovers and 2%THD, but I've found something that I think is more practical to spend it on. You must realize that some people like cool stuff, especially cool stuff with overkill (and headroom, in the case of sound systems). I'm one of those people. I feel that this system could actually be something worth having, and I will certainly be very happy if and when it is done (the only reason that it might not get done is if you people convince me not to build it, or refuse to help me with my speaker issues, etc.). In conclusion to that, I'm building it as a huge outdoor stereo that can double as a killer PA, immediate listeners will probably just include myself and my friends, and many of the system's channels may remain unused until such a time when they are called upon, and I certainly won't be able to afford ALL the speakers right away. I could get a taste of it fairly soon though.
As far as my experience in such things, it is little, and it is far less than my book knowledge of the matter. I have built a few power amps, have worked with a few home theatre and car systems, but nothing anywhere near this magnatude and complexity. I haven't had the opportunity to, and the best way to learn that I have is to just go do it, but with a little help from people that have more experience than myself, of course.
I have been "totally honest", and I hope I have answered all your questions. Perhaps I can make some real progress soon, if my current speaker plan sounds good to everyone.
Mosfet Amplifier Telnet100 Solid State 1 28th January 2009 02:56 PM
MOSFET amplifier ash_dac Solid State 6 5th December 2006 09:55 AM
MOSFET/MOSFET amplifier jarek Pass Labs 21 22nd June 2004 06:04 PM
Page generated in 0.11231 seconds (87.49% PHP - 12.51% MySQL) with 11 queries
