Old 30th May 2011, 07:35 PM   #1
Alaza is offline Alaza  Denmark
Default How to fix idle noise on 50 year old Bang and Olufsen
Hello there,
I'm trying to put some life back in to my 40-50 year old Bang and Olufsen Beolab 5000 stereo amp. Basically I've changed most of the caps in the output stage (not the ones in the feedback yet though), and I've been cleaner the potentiometers with contact cleaner.
I still get quite a high humming noise in the speakers when having the volume at 50% and upwards. Is it dried out caps, or should I be looking somewhere else?
I know it's a bit vague, but hope you can point me in some direction.
Tore
Old 30th May 2011, 10:53 PM   #2
djoffe is offline djoffe  United States
sounds like power supply filter caps have lost their capacity, leading to much hum on the power supply. Have you checked those?
Old 31st May 2011, 06:42 AM   #3
That could definitely be the problem. But how is it that it influences the output of the amp, if the caps in the power supply is dried it? There is three caps, two 50uF and one 80uF.
I'm not the a power supply expert, so I'm not entirely sure of their design purpose, but I've uploaded the schematic. The quality is really bad, but I can't find anything better at the moment.
Old 31st May 2011, 09:48 AM   #4
harrydg is offline harrydg  Belgium
Send a message via ICQ to harrydg Send a message via MSN to harrydg
i'd start with the 2500uF cap next to the 4 diodes after the transformer (dammit, terminology is failing me at the moment :s)
Old 31st May 2011, 02:18 PM   #5
I already changed that, along with two 3000uF that are connected on the output. I have added the output stage too. Why would you put caps on the output like that?
Old 31st May 2011, 09:09 PM   #6
Old 19th April 2012, 10:52 AM   #7
his047 is offline his047  United Kingdom
Hi Alaza,
I would guess that the output caps are there for protection: many years ago when I taught English to Danes in Copenhagen one of my students was an Old-Style electronics engineer. He swore blind that this kind of circuit could not work!
On a different note, I have just bought a set Beolab/Beomaster 5000 and I am looking for Circuit diagrams. Is there any chance you could send me those (off-list)
All the best
Frederik
(A Dane in Scotland)
Old 22nd April 2012, 07:06 PM   #8
djk is offline djk
djk's Avatar
If the hum increases with volume it is coming from the pre-amp, either that or you are using a turntable?
Candidates for the Darwin Award should not read this author.
Old 22nd April 2012, 08:07 PM   #9
pdul is offline pdul  Denmark
[QUOTE][/QUOTalready changed that, along with two 3000uF that are connected on the output. I have added the output stage too. Why would you put caps on the output like that?
With single rail ps you will have half of the voltage standing on the output. So to save your speaker from dead by frying. It was normal in many amps back then
bang olufsen help N-Brock Multi-Way 3 31st August 2008 05:57 PM
Bang & Olufsen connectors pinout? Bricolo Parts 7 30th May 2008 01:19 AM
Bang and Olufsen Powerlink Control Protocol Marekvb Multi-Way 0 30th May 2008 01:19 AM
Bang & Olufsen Beogram 1023 Nordic Analogue Source 10 23rd December 2005 08:52 AM
Bang & Olufsen Loudspeakers zx3chris Multi-Way 15 9th December 2003 06:53 AM
Page generated in 0.09622 seconds (83.93% PHP - 16.07% MySQL) with 10 queries
