Old 30th May 2011, 12:04 PM   #1
seanvn is offline seanvn  Viet Nam
Default 1/f noise in transistors
As far as I understand there has never been a satisfactory explanation of 1/f noise in transistors. Given that transistors must be the most studied form of physical device in existence both theoretically and practically that seems a little odd. I have just been reading about the GEO600 experiment in Germany that aims to detect gravity waves. Well they didn't find any but what they did find was an unexpected source of noise in there system that they could not account for. It has been put forward as a suggestion that this noise is actually 'holographic noise' that is present in the space-time structure of the universe. If true then it would be reminiscent of the discovery of the cosmic background radiation by Pinziaz and Wilson in 1964.
Perhaps we have beaten the GEO600 team to it and our humble little transistors are detecting the 'holographic noise' of the universe as 1/f noise?
Gravitational wave detector in Hannover tests holographic Universe ? Can GEO600 hear the quantum noise of spacetime? — GEO600
GEO 600 - Wikipedia, the free encyclopedia
Old 30th May 2011, 01:11 PM   #2
Hi seanvn
The attached article from 1993 provides insight into I/f noise in semiconductors. Simply put as I read the correct use of current in a circuit can dramatically benefit the unwanted ingress of noise, and as current reduces -so does bandwidth.
I reflect on the lifetime work of David Blackmer founder of DBX and his quest for higher bandwidth in audio David E. Blackmer - Wikipedia, the free encyclopedia
Ben Duncan audio engineer, to the best of my knowledge has contributed extensively in measuring real components that we use in electronics and discovery of noise and its
side effects. He has also led many an engineer toward Robert Pirsigs book Zen and the Art of Motorcycle Maintenance an important book describing in part the difference of persons who are analytical vs those who gloss over fine detail.
Cheers / Chris
Old 30th May 2011, 01:19 PM   #3
Article Noise attached was too large in .pdf trying in jpeg Here is the URL http://www.ini.uzh.ch/~tobi/anaprose/noise/noise.pdf
Cheers / Chris
Low noise transistors for electret mic Katman Analog Line Level 17 2nd May 2012 12:27 AM
Rohm very low noise transistors 2SD786 and 2SB737 ticknpop Swap Meet 1 7th March 2011 12:50 PM
ultra-low noise transistors. PCP Solid State 44 10th February 2011 10:14 PM
Recommended transistors for audio applications (low noise,....) kosmos1 Solid State 7 31st July 2010 11:15 PM
noise from new output transistors peter pkcc Solid State 7 31st May 2001 04:05 PM
Page generated in 0.10345 seconds (64.31% PHP - 35.69% MySQL) with 11 queries
