Old 27th May 2011, 08:25 PM   #1
Default opamp output - how to make its impedance higher?
ok, so an opamp output impedance is low, but how can I make it higher so that it s output wouldn't load down passive guitar pickups? The end goal here is to integrate an extra active piezo pickup preamp output into a guitar's traditional switching scheme
Old 27th May 2011, 08:47 PM   #2
nigelwright7557's Avatar
I think you mean input impedance.
Make the guitar coil output go into the non-inverting input.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 27th May 2011, 08:58 PM   #3
No I don't!
I want to mix the active output of a piezo pickup preamplifier (low impedance), into a guitar's high impedance wiring scheme.
The low impedance of the opamp output will load the pickups down...so was just wondering if it's simply a matter of putting a large resistor in series with the opamp output to help align the output impedance of the piezo preamp with the passive pickups.
Old 27th May 2011, 09:01 PM   #4
OK with you now.
One way is to just put a resistor in series with the output of the op-amp.
Or use anotehr op-amp to buffer and mix the two signals.
Old 27th May 2011, 09:11 PM   #5
Xoc1 is online now Xoc1  United Kingdom
Xoc1's Avatar
I would probably link in a high value variable resistor - say 100k or more to start with, and then adjust the pot until its a reasonable match. Then measure and subsitute a fixed resistor.
Old 27th May 2011, 09:18 PM   #6
Originally Posted by nigelwright7557 View Post
OK with you now.
Or use another op-amp to buffer and mix the two signals.
but this would then make all the guitar's pickups 'active' (which changes their tone due to their output being low impedance)
looks like a series resistor is the way to go.
Cheers.
minimum load impedance for DIY opamp F1 FAN Pass Labs 2 15th September 2009 02:21 AM
Higher output of TL082 Ragnwald Solid State 6 7th June 2009 08:59 PM
looking to make a higher end portable 12v amp,sugg.? elecres Solid State 2 6th May 2009 12:55 AM
Higher impedance = cleaner volume? JonnySwitchblade Multi-Way 8 10th July 2007 06:58 PM
Page generated in 0.11587 seconds (66.98% PHP - 33.02% MySQL) with 10 queries
